Results 1 to 20 of 20
Thread: 340k-mile 528iT??
    Dec 2020
    San Jose, CA, USA
    1994 "532i6", 1998 528iT
    340k-mile 528iT??
    So, two weeks ago I found this cleeeeean silver touring for sale on Facebook, and went to go take a look - it drove so well and had so many obviously new parts on it (the cooling system is literally all new parts) that I immediately traded my E34 touring in and brought her home. Someone clearly gave a f*ck about this car.
    With that said, the headlights are reps, the "eyeshadow" trims are black, there's a little shimmy from the front end that's *probably* the thrust arm bushings going out, and the shifter is the worst I've owned out of 8 cars. The cluster has been replaced as well, and in the service manual there's a note saying 135k = 235k... well, the cluster reads 240k now LOL. Checking out the CARFAX after the fact confirmed it, this car has a solid 340k miles on it but looks like 140k.
    Just look at the underside, new Billies, Eibach sways and just general cleanliness.
    The interior:
    While I'm kinda gloating, yes, I also earnestly want to know: HOW do you keep a car this clean for this long? I've owned and built track/race cars all my life to the point where I normally consider them as disposables. This is the first time I've encountered a car like this, and I do not want to waste the previous owners' efforts.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Congrats on your vehicle purchase
    I think I can help you on the approach that will give a vehicle a long clean life that at high mileage, so the car in question still looks good, drives like a low mileage unit. It starts with frequent wash and wax, under the hood and inside, then adds in the care taker approach to preventive care maintenance that says fix every thing as it needs it, replace worn service parts before they fail, then check frequently to ensure everything is ok, and then add a little UV protection product to everything leather, vinyl or plastic. The "drive it like you stole it" followed by put away wet after hard uses, always ends with a vehicle that is worn out long before it's time. You can see this later group's vehicles a mile away. Bent wheels, parts way past their service life still in place, broken and cracked trim parts everywhere, and opening the hood is like cracking open a coffin after years beneath the earth's surface.
    Driving style either promotes long life or a trashed car with loose McDonalds rappers sliding around inside. Think of the got to be first off the light crew followed by the last to brake at a light driving style.
    question, why is it the top 10% cars in every class, always look clean and well prepared and the back markers look like they come from the last chance garage?
    Bottom Line: E39's are over engineered, over built and when closing a door, they sound like a bank vault. It is all around structural integrity that was built in.
    If you keep the practices that the previous owner had, you too will have a longer life car. Now, stay away from Rust Belt owned models as a winter driver has a very short life regardless of owner care.
    i will jump off the preaching stool now.....
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Shoot, I have a clean silver 525iT with 375,000 on it. Take care of it, and it will reward you.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    This thread gives me hope. What bums me out is all the wagon parts that are NLA. Including the rear window seals...sun in the South is not your friend.
    “She’s the last of the V8’s, she sucks nitro...phase 4 heads, twin overhead cams...600 horsepower through the wheels, she’s meanness put to music...”
    Dec 2020
    San Jose, CA, USA
    I suck at getting pictures on the post, yes I do. Fixed the OP.
    I fixed the one really obvious fail - a missing muffler - for $240 at my friend's local muffler shop. Looks and sounds perfect now, just enough to hear what rpm's I'm at (the tach lags, it's useless to me) but dead silent at cruise and idle.
    I also managed to crack what looks like a brand new Behr expansion tank.
    So I went in there and replaced it with a new Rein unit, and while I was in there, I wasn't sure if the thermostat was good so I removed it, and it turned out to be literally brand new as well (the rubber gasket had not even had time to soak in the blue coolant color). Oh well, I have a spare 'stat now.
    Looking ahead, I found a set of OEM 2001 Xenons in good shape, a pair of new Hella euro lenses, and OEM euro Celis tails. Not sure how long it'll take me to get this all working (I know I'll be making new 12V regulator/resistor loops for each LED array) but it'll be good to have factory headlamps again, for safety, and an updated set of tails to match.
    Feb 2014
    Alexandria, VA
    I am in the process of stripping my green wagon for a complete paint job. These rear side window gasket not being available sure is a bummer. Painter says he can shove the foam roll they wedge in there to pull the edge away from the body. I got the gaskets for the rear door quarter windows, but I want those rear window gaskets too, sometimes, these Latvian ebay guys come up with some new old stock, just have to keep checking for them.
    Jun 2010
    Bay Area, California
    325iT, 540iT
    I just took a quick look through the parts catalog. ECS is showing 51-72-8-190-632 in stock but not -631 for the left side. Time to buy up the last ones? Alternatively have you talked to an automotive glass shop or euro dealers? The wagons are relatively rare here but were pretty common in Europe they're probably going to be on the road for a few more years yet. I figure given some time BMW will probably make another run of these.
    Dec 2020
    San Jose, CA, USA
    eBay Latvia FTW. For a lot of the smaller miscellaneous seals though, I've gotten into the habit of literally crafting a new one using 3M Window-Weld. Going to be doing that for the rear door quarter-windows as the factory gaskets have crumbled into dust and it's a dumb part to have to re-gasket every decade.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    The Behr service units are crappy, and that is generous. Don’t overfill - the red stick should be just below the lip. A OE dealer part is worth it here. The one in the pic is way overfilled. Looks like you did well.
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Quote Originally Posted by blarf View Post
    To all the wagonistas reading this, a word of caution.
    That part number is for the interior fuzzy strip between the headliner and interior side panel.
    The exterior window gasket is only available with the window.
    Only a few left and basically $500.
    Not enough room for past/present garage
    Jun 2010
    325iT, 540iT
    Quote Originally Posted by wagons ho View Post
    Ah good to know. That was listed on the diagram with the "Green side window with gasket". More interesting is that they're showing a different part split at Sep 2003 build. I wonder what the aftermarket availability is like…
    http://bmwfans.info/parts-catalog/E3...ixed_position/
    Nov 2016
    NY
    Likely 0. Sept 2003 sounds like the end of the line for e39.....
    Dec 2020
    San Jose, CA, USA
    Time to make some incremental changes, hunting for fuel economy. Aero is never a wagon's strong suit, so I picked up a cheap spoiler to test whether or not lengthening the roofline would help.
    VHB for test mounting.
    Test loop is simple, here in the Bay Area CA we have a lovely stretch of I-880 that's almost perfectly flat, consistent wind speeds and direction for the most part, so you can do A/B testing with cruise control starting from defined points along the route.
    Short answer if you're curious -- it didn't seem to do anything, no significant gain or loss at the angle I had it mounted. Since it was a little higher than ideal, I suspect it wouldn't hurt to try again with a lower mounting angle, but that's going to be a permanent install if I have to glue it (liquid thinner than solid foam tape).
    In the past few days I think I've developed a driveline vibration, so one of these weekends I'm gonna have to check out the guibo... what other failure points could cause a periodic (vibration phases in, then out, then in, then out) vibration from the rear end, starting from around 65mph? Gets stronger as the car approaches 80-85mph.
    Feb 2014
    Alexandria, VA
    Guibo and the center bearing on the driveshaft suport.
    Dec 2020
    San Jose, CA, USA
    I finally tracked down the source of the vibrations - the guibo was old yes, but it was literally a harmonic from the rear wheels. F*** replicas lol. Found a set of 219M's for cheap on eBay, sent them to the wheel repair shop anyways to 100.00% straighten them out, bored the centers open to 74.1 and bolted it up. Instant +1/+2 to fuel economy, all the rear end vibrations solved.
    Now we've got more cooling system issues (aux water pump dead - guess it just doesn't bleed properly) and what feels like bushing shimmy in the front end, so time to put in another FCP Euro order and get this whiny brat sorted.
    Dec 2020
    San Jose, CA, USA
    Haven't updated this thread but the car's been through quite a bit.
    Long story short, the engine blew headgasket after the expansion tank burst and lost coolant. So I went looking for a replacement M52TUB28 while starting to tear the engine bay down with the help of a friend.
    20220210_181106 by Brian Ma, on Flickr
    Side note, circular harnesses are retarded.
    20220210_201623 by Brian Ma, on Flickr
    Thank god for that friend because me taking apart the M52TU intake manifold alone isn't happening without a manual.
    20220211_181404 by Brian Ma, on Flickr
    Other threads have documented this better than I ever will, so, let's just say the engine came out.
    20220211_181424 by Brian Ma, on Flickr
    20220211_181416 by Brian Ma, on Flickr
    For fun, yanked the old plastic coolant pipes off by turning a 3-jaw puller into a 1-jaw. Nasty.
    20220211_221247 by Brian Ma, on Flickr
    In an absolute stroke of luck, someone on eBay had run out of funds to finish their 2.8L Z3 project, so I found a listing for a car with no engine, and a suspicious description for a 2.8L engine with perfect compression numbers pulled from a Z3 project. Brought it home and started to inspect.
    20220211_181411 by Brian Ma, on Flickr
    Looks perfect to me, there was a little bit of grit in the intake tract from sitting so I vacuumed that out.
    20220211_221702 by Brian Ma, on Flickr
    Only had to swap over a few things (motor mount arms, oil pan) and replace one-time-use hardware like exhaust studs.
    20220212_160448 by Brian Ma, on Flickr
    The inside of the engine looks a little varnished but I didn't find any grime at all.
    20220212_144533 by Brian Ma, on Flickr
    Ready to go back in:
    20220212_001136 by Brian Ma, on Flickr
    New engine in...
    20220212_211247 by Brian Ma, on Flickr
    ... and what an engine it is. I never imagined an old inline-6 can get anywhere near 40mpg, but here it is in a wagon getting fairly close. With a few tricks applied it actually has the potential to get there!
    Cruise-controlled on level highway, no wind, a bit under 65mph.
    You don't have to be astute to notice the gleaming SLS light, which, at least that's a pretty easy fix. I replaced the sensors (they were old) and the air pump (it had no compression even though the motor would turn) and all is now well there. Which then leads to the fun part, upgrades
    PXL_20221026_041359615 by Brian Ma, on Flickr
    Since this wagon is to be the go-anywhere car I wanted to give it a mild lift and bigger tires (height only to make space for articulation and snow). Working SLS makes this so easy. I could even corner-balance the car if I feel like it down the line haha.
    PXL_20221026_041746630 by Brian Ma, on Flickr
    In the front, just raising the suspension will produce positive camber in the front wheels, so I had to find something that both lifted and corrected for camber. Hello Ireland Engineering. I picked up a pair of E46 adjustable camber plates and drilled one extra hole for the E39 top hat to fit.
    PXL_20221026_231409147 by Brian Ma, on Flickr
    Pretty easy install after that, and it totally works.
    PXL_20221026_234548768 by Brian Ma, on Flickr
    Here's how it all looks together with some Wedssport TC105X Gravel mounted up. Tires are 215/70/15 Yokohama Geolandars and they're excellent. Thanks to the effectively taller gearing, there was no MPG hit of using all-terrains, the wagon still returns mid-30's to almost 40's on the highway.
    PXL_20221111_212900386 by Brian Ma, on Flickr
    I still have some ways to go - the replica M5 bumper is getting thrown out for an OEM 530i bumper, have to diag and fix a fuel leak near the left side saddle tank, and more parts are waiting to be installed to try and improve on aero. But things are looking good for this wagon and I've enjoyed driving it everywhere the last few thousand miles!
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    As you may have noticed, M52TUB28's are getting harder to find. You should bring your old motor back to life. I don't care how many miles it has on it.
    Get the head fixed, new piston rings, conn-rod bolts and bearings.. Main bearings if you want to - not needed, and sell it on...
    My M54 ('03 530i) has 418k
    Dec 2020
    San Jose, CA, USA
    I wouldn't say that no, I find five M52TUB28's for every M52B28 (iron block) that I go looking for. The only thing I really feel like keeping from the original engine here is the crankshaft; the cams were scored, lifters seized, low compression in several cylinders so I assume the cylinder walls were scored. It's just incredibly difficult to get compression/leakdown numbers from most sellers so having confidence in the engine is hard.
    If this engine lets go, I'll build another one then. Having an engine built and sitting for years is almost as bad as having no engine at all.
    Dec 2020
    San Jose, CA, USA
    Creeping up on 360k miles now, figured I'd update the thread.
    I gave up the TC105X's to go on my wife's Accord, so the wagon had to borrow wheels from my track car. Looks good but definitely less comfortable ride quality:
    PXL_20230404_063323498~2 by Brian Ma, on Flickr
    Finally got around to addressing annoyances like this stuck hinge - kudos to The Studio Presents for knocking this out while I was at work and adjusting all the panel gaps afterwards.
    PXL_20230617_013827088 by Brian Ma, on Flickr
    Got a BMW roof box for cheap, truly used only a few times though so now it's on a friend's Subaru lol.
    PXL_20230603_175329241 by Brian Ma, on Flickr
    Simply enjoyed the car for several weeks, which was the whole point of buying this thing in the first place.
    PXL_20230722_181116103~2 by Brian Ma, on Flickr
    Recently I got the itch to replace the old Wedsport combo with a "more BMW" all-terrain package. Still wanted a 27" tire but wanted wider for stability. Long story short, I found a 235/60/16 set of Geolandar G015's that looked just right on some 16x8 Maxilite Alpina Softlines.
    PXL_20230726_230610240~2 by Brian Ma, on Flickr
    I love G015's for the blend of on-road niceness / decent grip and safety / can climb hills in the snow, so the performance and aesthetics make me a happy camper.
    Oh yeah, the replica M5 bumper did get tossed, although the replacement 530i bumper isn't exactly a keeper either. Still hunting for a good one before I spend the effort to paint and mount an Alpina lip.
    PXL_20230818_165443645 by Brian Ma, on Flickr
    Feb 2014
    Alexandria, VA
    Jeez! How many sets of wheels have you gone through??? I’m still on the same style 66’s, mileage ticked up to 389,000.
  1. 2002 X5 M54 with 340k miles Leaking oil on exhaust. Oil Pan Gasket?
    By MHRX5 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-31-2020, 01:02 AM
  2. 2000 BMW 528iT, Black on Black Touring Wagon less than 81K miles - SOLD
    By ronrooney in forum BMW Cars For Sale / Wanted
    Last Post: 10-14-2013, 01:32 PM
  3. 1999 528iT, 128k miles. Palm Desert, CA, $3750
    By Racing Roman in forum 5 series & 6 series
    Last Post: 07-08-2013, 02:16 PM
  4. FS: 99 528iT only 70K miles, great condition
    By HUDbaby in forum 5 series & 6 series
    Last Post: 01-30-2008, 12:49 AM
  5. FS: 2000 BMW 528iT, biarritz blau, 91K miles
    By Savman in forum BMW Cars For Sale / Wanted
    Last Post: 02-18-2007, 12:26 PM
