BAVToys
Results 1 to 6 of 6
Thread: E36 How to save weight on headlight?
    Nov 2020
    Cologne
    323ti 318ti
    Hi
    Does anyone know how to save some weight on headlights? Are there plastic headlight lenses (outside) that would replace the original glass ones?
    I3MW's Avatar
    I3MW is offline /////////////////////////
    Boston
    81 320i, 02 WRX
    I gotta ask. What is the goal here? I don't think there are plastic lens to replace the Euro units. You could always go with the crappy US spec but that seems like a downgrade IMO. Couldn't tell you the weight difference either. If this is a race car just install a delete plate and/or possibly air ducts. If it is a street car there is no performance to be gained here.
    Nov 2020
    Cologne
    323ti 318ti
    The car is a motorsport car and will be used in rally. For a street car it will not make sense but in that usecase weight it in fact an important part of performance. Weight distribution is about 54% front 46% rear therefore that question occurs.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    that does not make a big difference, sound insulation removal brings a lot https://www.bimmerforums.com/forum/s...ight+reduction
    Floor covering front 19.4 lb
    Floor covering rear 1.4 lb
    Trunk mat 4.3 lb
    Trim panel right 1.3 lb
    Luggage compartment pan 0.9 lb
    Insulating mat 3.4 lb
    Trim panel left 1.2 lb
    Headlining 3.7 lb
    Headliner, sunroof 3.3 lb
    Rear window shelf 6.3 lb
    Sound insulating engine hood 1.6 lb
    Hood 34.2 lb, a carbon hood https://edenhofer-motorsport.de/prod...36-motorhaube/
    E36 Carbonteile https://www.cf-dynamics.de/carbonteile/e36.html
    cpl. headlight left or right has a weight of 5.5 lb
    Nov 2020
    Cologne
    323ti 318ti
    Yes insulation removal is the best way to loose fast and cheap weight. Therefore all these parts allready gone + every unnecessary bracket etc.
    Fiberglass hood will follow maybe.
    That is the reason why headlights come in play.
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    Someone should be able to send you some plastic headlights for free from the US. Though may take a while to get to Cologne.
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
  1. E36 BMW E36 3 Series EURO FRENCH YELLOW Headlights OEM BOSCH European M3 GT Alpina
    By EuroBM in forum Exterior Lighting & Body Parts
    Last Post: 12-22-2013, 06:20 PM
  2. E36 E36 coupe amber corner signals for headlights
    By BadE36 in forum Exterior Lighting & Body Parts
    Last Post: 02-24-2013, 06:12 PM
  3. E36 wtb:e36 m3 sedan drivers side depo headlight for retrofit
    By rohner88 in forum BMW Parts Wanted
    Last Post: 08-06-2012, 12:39 PM
  4. E36 DEPO BMW e36 Euro Nipple Ridges Projector Glass Headlights PnP
    By CristaGalli in forum Exterior Lighting & Body Parts
    Last Post: 05-04-2012, 12:21 PM
  5. E36 M3 Coupe: Lexan weight savings
    By Ben7117 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-13-2009, 07:36 PM
