Hi,
I'm working on an art project using recycled BMW headlamps (almost all LEDs). I'm able to turn the DRLs and other externally mounted LED modules by snipping the wires leading to the connectors and directly providing power/ground connections to the modules.
I've had more difficulty with the beams since they are extremely difficult to physically access inside the headlamp assembly.
I've been able to turn a few of the beams on by removing the FLE2 module and luckily identifying power and ground for the beams. Would be much easier if there was a pinout for those connectors - is there anywhere I can find that information?
Alternatively, is there a way to provide a digital bus signal to the lights and control them that way?
Understand this is a complex topic that is not typical usage for these objects, but figured I might be able to get some guidance here and start discussion...
