Start networking around the area.Originally Posted by 6i9
You'd be surprised @ how many ppl are willing to help out...just to be able to work on your car.
You just have to be a little savvy about it.
'00S52 RETIRED
'07 Silver Gray E86 MCoupe
Networking? What do you mean?Originally Posted by tripleM
I don't know the first place to look for a good BMW body shop. I tried asking on various regional forums, with no luck.
That's totally bogus, if you had asked around any of the DC Metro boards, Wagon Worx would have popped up several times.Originally Posted by 6i9
The point to this is,Many of us here don't have the first clue on how to do the solutions that Randy or dvm have come up with. But I'll bet you they didn't either until they start chatting it up w/ friends, family, strangers. It's all about being entreprenurial & going out & seeking what you need even if it's a dead end most of the time.
The Z3 community is soo kool because of the grassroots engineering solutions that are being invented all the time. & I dare say most of it comes about by just hanging out & shooting the sh!t.
The boards is one resource, the NCCA is another...you get the idea.
'00S52 RETIRED
You're right. I just need some connections. I'll check out this Wagon Werks place.Originally Posted by tripleM
It's probably doable, but it's crude. I don't like to put a torch to a structural component like a subframe if I can just buy a tool and do it quickly and effortlessly without a torch nor hammer. Call me anal-retentive, but there it is.Originally Posted by MMpire
Plus the differential cover mount, plus the swaybar (via the trailing arms), plus brake lines and sensor wires... yes.The subframe is only connected to the car via the shocks, 2 mounts with bushings we are going to replace, and the drive shaft? Does this sound right?
Looks "factory" from the bottom. A few more pictures are posted on b'fest.
Try this instead:Originally Posted by 6i9
<a href="http://www.rfdm.com/SubframeBushings/howto.html">
http://www.rfdm.com/SubframeBushings/howto.html</a>
Needs more pictures and tool information, but if you read through it, then look under your car, then read through it again, it should all fall into place in your head. The key thing to think about is that it's just those three points truly holding up the subframe... the two subframe mounts with bushings we're replacing, plus the differential cover mount. The rest is just things you need to get out of the way to get to the task at hand.
That looks like it's a lot more thorough. Thanks for the writeup.Originally Posted by dwm
does anyone have information on where I can rent this tool? and how much it goes for?
thanks
-Kyle 1995 Custom Turbo M3 SOLD!
