Results 1 to 16 of 16
Thread: M30B35 hunting idle
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    M30B35 hunting idle
    So my car has a hunting Idle after about 45min of driving or after it sits for an hour and I try to restart it. It will start perfectly fine after after it cools off so about 5 hours. There is a strong smell of petrol when I try to start it up when its cold, I think bad o-rings on my injectors, (hates cold starts). I've replaced my ICV, Purge Valve, fuel pressure regulator, fuel filter and also upgraded to the miller gen III MAF, I'm doing a fuel pressure and vacuum pressure test tomorrow as well as a smoke test. I have also done multimeter tests on all of the connectors of parts I replaced.
    I have been lost trying to figure this out for the past month.
    Any solutions or other threads that go over this issue (I have already gone over lots of the threads for idle problems or stalling issues).
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Hi from Quebec I don't have a solution for you unfortunately but I just wanted to say that I have the same issue on my 735iL (same engine as your car).
    In fact I just placed an order for new Bremi spark plug wires in the hope that it will fix my hunting idle.
    I will be following this thread, hopefully you can find a solution!
    90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
    May 2009
    Bangkok, Thailand
    5/93 E32 730i M30
    Have you looked at swapping the MAF over for a known good one ... ??? Also be interested to see results from vac tests ... that is often a cause of hunting ... ...
    NW suburban Chicago
    hiss by my window
    Given a stock set up I'd say just a vacuum leak that the ICV is trying to deal with. Given the MAF, ??
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    Okay so I did a smoke test and found that I have a leaking valve cover gasket. I also did a vacuum pressure test and came out with 14psi at 1000rpm. I have tried it with both my OEM MAF and the miller gen III and still the problem continues.
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    More news, after driving back from my school it has started backfiring upon stepping on the gas to hard and has horrible throttle response now and also bogs down when you ease onto the throttle
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    Did you plug the AFM back in?
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Joe.f View Post
    What?
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    Quote Originally Posted by ross1 View Post
    What?
    So I did the vacuum test and the idle was jumping around 900-1200rpm and the PSI was jumping around from 11-15PSI so I held it steady at 1000rpm to stop the hunting and the pressure evened out to give me my 14PSI reading.
    Wisconsin
    '95 525it
    The measurement is inches of mercury, or in/hg. 11-15 is low, suggests a vacuum leak.
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    So more news, I installed a inline fuel pressure gauge and the pressure started at about 40 psi and then sat around 38 psi after a little bit of driving and when it started to hunt the pressure didn't change. So just wondering if anyone has any ideas from hearing that on what my problem is
    Feb 2008
    Nashville, Tennessee
    1978 635Csi, 1988 735iM
    Yeah, no one is saying it outright but you have a big leak. Did you fix the valve cover?
    there’s also a tiny gasket at the rear of the head that can cause it too.
    You also need to check the tube running into the idle control valve, vacuum hoses, and the vacuum tube going to the brake booster (if you have vacuum boosted brakes).
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    Quote Originally Posted by 6erWEBB View Post
    Ok I'll do another smoke test, I did the valve cover and that was the only spot I had a leak but I'll do another one to make sure I didn't miss any
    Feb 2008
    Again if you have vacuum boosted brakes I can tell you from experience that the booster can leak internally and cause a vacuum leak but not show up with a smoke test.
    Dec 2020
    Kelowna BC Canada
    1991 BMW 535i
    Okay, thanks I will check and then get back.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    also check the ground cable from engine to chassis,
  1. surging/hunting idle when cold..help!
    By romeox929 in forum 1988 - 1996 (E34)
    Last Post: 03-03-2007, 09:03 PM
  2. Hunting idle
    By felipe53 in forum 1988 - 1996 (E34)
    Last Post: 10-06-2006, 03:57 PM
  3. 1991 318is Hunting Idle
    By ak96ss in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-28-2005, 11:12 PM
  4. hunting idle help !!!!
    By mr bmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-29-2004, 03:50 PM
  5. Shaking and Hunting Idle
    By C.Yang in forum 1992 - 1999 M3 (E36)
    Last Post: 03-24-2001, 04:05 AM
