Results 1 to 2 of 2
Thread: Clutch problem need help or advice
    May 2014
    Philippines
    BMW e46 sedan m3/ls3
    I have a bmw e46 with a ls3 and tr6060 transmission in it but I am thinking or having problems have rebuild the transmission thinking it was the problem but looks like it’s more then the transmission on cold start and using for early the gearing world perfectly but once it gets to hot running temp the gear grinds when shifting to second gear and notice that if I am on a full stop pressing the clutch pedal all the way down and rev engine the car moves forward so am thinking it’s got to do with the clutch pedal and the Hydrolic system of the transmission I am sousing stop bmw pedals would you have solution I can do to fix this or a kit like maybe a new pedals box and a Hydrolic system or something I hope you can help me also want to put a cooling system for the power steering do you have also thanks
    Dec 2020
    Las Vegas
    1995 BMW E36 318ti
    How is your pedal fells? I think that it in not the pedal. It seems you have a clutch engaging problem or something wrong in the tranny itself. That is why car moves when you rev it while you press the pedal all the way down. Bleed the system with a vacuums system. Check fluid quality. Look for any ballooning of the hose. What is the transmission oil you are using? How old is it? If T.fluid is thinner than required standard, syn wheels find problem with engaging properly.
  1. Clutch problem. Need help to diagnose
    By bmwvsevo in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2009, 12:36 AM
  2. Acute Clutch Problem, need help diagnosing
    By GacAttack in forum 1991 - 1999 (E36)
    Last Post: 02-01-2009, 03:42 PM
  3. clutch problem - need help
    By Dori Ninja in forum 1991 - 1999 (E36)
    Last Post: 01-07-2006, 05:50 PM
  4. Clutch problems need HELP!!
    By 89325iturbo in forum 1983 - 1991 (E30)
    Last Post: 03-18-2005, 12:10 AM
  5. Bad Clutch Problem, need help ASAP
    By UrReflector in forum 1992 - 1999 M3 (E36)
    Last Post: 02-28-2005, 12:31 AM
