I have a bmw e46 with a ls3 and tr6060 transmission in it but I am thinking or having problems have rebuild the transmission thinking it was the problem but looks like it’s more then the transmission on cold start and using for early the gearing world perfectly but once it gets to hot running temp the gear grinds when shifting to second gear and notice that if I am on a full stop pressing the clutch pedal all the way down and rev engine the car moves forward so am thinking it’s got to do with the clutch pedal and the Hydrolic system of the transmission I am sousing stop bmw pedals would you have solution I can do to fix this or a kit like maybe a new pedals box and a Hydrolic system or something I hope you can help me also want to put a cooling system for the power steering do you have also thanks
How is your pedal fells? I think that it in not the pedal. It seems you have a clutch engaging problem or something wrong in the tranny itself. That is why car moves when you rev it while you press the pedal all the way down. Bleed the system with a vacuums system. Check fluid quality. Look for any ballooning of the hose. What is the transmission oil you are using? How old is it? If T.fluid is thinner than required standard, syn wheels find problem with engaging properly.
