Results 1 to 13 of 13
Thread: Offset LCAB part number confusion
    Dec 2018
    Germany
    1990 E30 325i 4 Door
    Good morning,
    I am replacing the LCABs and found two part numbers, help correcting me if i got this information incorrect:
    31129061222: This is specific to the E30 M3
    31129064875: This is specific to the E36 M3/Z3 M
    Both parts fit, but the 875 is the stiffer offset version?
    Does it matter which one i order? and these are always sold as a set/pair correct? meaning i need to order just ONE of those and i should receive two pieces correct?
    Thank you.
    Oct 2003
    Seattle
    99 M3
    The offset bushings added caster to the E30M3 and 1995M3. The 1995M3 FLCAB part was offered as an ‘option’ on earlier non-“M” Sport and “M”-Technic E36s.
    E30
    31129058931
    Set rubber mounting f wishbone (centered - open, very compliant)
    E30M3
    31129061222
    Set rubber mounting eccentric (offset - closed)
    E36 95 M3 (similar to E30M3)
    RUBBER MOUNTING F WISHBONE 31129064875 (offset - closed)
    96+M3 / Z3 “M”
    RUBBER MOUNTING WISHBONE 31129069035 (centered - closed)
    318/325/323/328 / Z3
    RUBBER MOUNTING F WISHBONE 31129059288 (centered - open, very compliant. different configuration than E30)
    For all (‘lollipop)
    LH WISHBONE BRACKET 31121139789
    RH WISHBONE BRACKET 31121139790
    Use a Temporary Assembly Lubricant to aid installation of ‘lollipop’ to FLCA
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Good info right there!
    Quote Originally Posted by bluptgm3 View Post
    For all (‘lollipop)
    Would this be an appropriate lube for doing the rear trailing arm and subframe bushings as well?
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I bet it is.
    on helicopters, we use Crisco for assembly of O-rings and packings in engine oil and fuel systems. we use something similar to the one you asked about when building transmissions and gearboxes because sometimes they are grease filled. I bet that is used for what you asked
    No e30s again.
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    For whats its worth, whenever I do suspension bushings I use Marine Grease. It is more water repellent and typically formulated to not break down when exposed to water, as well containing more anti-corrosion properties. Ive noticed it lasts quite a bit longer before you have to re-apply, say for instance if youre running "Poly" bushings that will creak if they get too dry.
    Mar 2013
    So~Cal
    Quote Originally Posted by superj View Post
    I bet it is.
    Very cool, I was close to becoming an Aviation Mech, back when I was enlisted in the Coast Guard. Was too impatient however and couldnt last the 3+ years it took to get into training. I have had alot of friends however who stayed in it for the long haul end up in your neck of the woods (corpus) at the air - stations and small boat stations. Someone once told me that the E30 community has a high number of people involved in aviation...
    Dec 2005
    No e30s, again :(
    I bet they do have lots versus other jobs
    I knew a number of coast guard guys, years ago that have since pcs'd to other posts.
    I was thinking of doing coast guard auxiliary when I retire from ccad
    Just to stay busy
    No e30s again.
    Dec 2018
    Germany
    Dude, thank you for posting that info, it is valuable.
    I so for my E30, i should go for the 222 number?
    Lastly, i was planning to purchase the "special" bmw "montagehilfe (the special grease), but superj is right, an alternative to be used for all bushings around the car would be better.
    I shall search for P-80 in Germany, do you (or anyone) have any alternatives?
    Dec 2018
    Germany
    Found the big 1L fluid version in Germany for €25.
    I do plan on removing the rear end and re-doing the bushings, looks like i answered my own question, but the BMW special grease is a bit cheaper and more easily ordered.....can that grease from BMW also be used all around the bushings of the car?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by H.J. 1981 View Post
    The P-80 temporary lubricant is intended for rubber/rubber coated/clad metal shell bushings.
    This might work for metal-on-metal installations, however it is not the intent.
    Dec 2018
    Germany
    Alright, the BMW Grease seems to be the winner then.
    This is the one: 83192405829
    Dec 2018
    Germany
    I decided to get the E36 M3 center bushings and i have one question.
    Since there is no arrow to align the bushing to the mount/bracket, i guess those two notches on the sides are what one needs to pay attention to and align to the bracket marking(s) when pressing them in?
    Similar to this?
    https://www.turnermotorsport.com/p-5...-bracket-left/
    Oct 2003
    Seattle
    99 M3
    Similar to this?
    Yes, that is correct.
  1. OEM AMP part number confusion
    By Bombay Badboy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-01-2012, 03:29 PM
  2. E39 OEM roof rack part number confusion
    By jacco in forum 1996 - 2003 (E39)
    Last Post: 07-13-2011, 12:44 PM
  3. Bilstein rear sport shock part number confusion
    By FritzE30 in forum 1983 - 1991 (E30)
    Last Post: 01-03-2010, 01:33 AM
  4. Touring Radiator part number confusion
    By Louiseven in forum 1988 - 1996 (E34)
    Last Post: 01-02-2008, 03:17 AM
  5. Oil Filter Part Number Confusion for S52's.....
    By MSH in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-16-2003, 10:49 PM
