Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 110
Thread: 1995 540I Cashmere Beige on Beige on Beige
  1. #51
    Nov 2020
    Oklahoma
    540i
    DINAN TCU Chip Install
    Quote Originally Posted by mrgraybeard View Post
    If you keep the automatic, you want one of these: https://www.dinancars.com/products/s...arts/D902-0262
    It raises shift points and brings kickdown on more quickly. Big bang for the buck, IMO.
    So I called my local Dinan dealer/shop and got ahold of one of these chips. Not a replacement for a manual, but...
    Holy Hell it is BAD ASS. Long story short, the gal who runs the shop had to call Dinan and after being acquired by Holley they were like "we don't offer these any more, but... let me refer you to our tech department" Tech dept. says "let me look in the back to see if we have any more of the eproms floating around", finds one, fires up the 486sx with the cathode monitor, boots up DOS, dusts off the 3.5" floppy with program files, rips a game of OG X-Wing vs Tie Fighter while waiting, and burns me this chip for the price listed on the website. (all of the last part happened in my head, but pretty sure that is how it went down.) This woke up the transmission. IT RIPS NOW. Before it seemed like it didn't know what it wanted to do, always shifting when I didn't want it to and not shifting when I did. It was lazy to downshift (even when smashing the downshift switch) and never could make up it's mind. Again, a ripper now all things considered.
    Install was easy; pull TCU, pull cover, remove hex screws, bend tabs, remove cover, remove chip cover, use tape covered screwdriver to gently pry out old chip, and as the terrible bentley manual states... install is reverse of removal but while you are in there break half of the tabs on the TCU cover accordingly...
    Maybe if we all keep bugging these tuner companies about old parts for these glorious machines they will keep making them. I know there is demand but I don't think they do. Would still like to manual swap this thing and am keeping an eye out for parts, but think I will be looking for a while.
  2. #52
    Wisconsin
    '95 525it
    Glad to hear you like the chip. Without it I probably would have gotten rid of my 540i long ago. I've driven over 175K miles with it, so you needn't worry about it being hard on the transmission.
  3. #53
    Aug 2019
    '95 540/6, '01 750iL
    Thats awesome. Really neat to hear these types of stories. Gives you some faith that a lot of these places are about more than just the money.
  4. #54
    Nov 2020
    Oklahoma
    540i
    Cooling system and Valve Covers
    June update, been a busy few months with a cross country road trip in the F150 and woodworking projects, but have been collecting parts all the while. I bought a spare set of valve covers off of a 530 parts car and dropped them off at the powder coater. They blasted, sprayed, and baked them. The magnesium is a little pitted but they look better than what was on there.
    In hind sight, I should have doused them in brake cleaner before dropping them off, all of the crud from the prior motor turned into powdered crud after baking. I spent a good hour yesterday with a brush and simple green to get them clean on the inside (brake cleaner will eat the finish). Hopefully my powder coater knew what he was doing with the magnesium and I won't be doing this again in a few years.
    I bought the CA tuned Silicon hose set with new clamps for the M60 and installed those, a new radiator, fan shroud, the OE shape reservoir return rubber line, and coolant reservoir. My old radiator was leaking and I want this car reliable for a couple trips I have planned later in the year. If anyone is going to Ozark Euro Rally or TexFest, hope to see you there!
    Don't mind those zip ties, waiting on the mounting hardware...
    The CAtuned kit fits really well. I thought the heater core/valve/reservoir pieces would be the hard part but they went on easily while the front hoses fought me the entire way. As for the coolant reservoir, the chinese made Mahle unit sucks and it is not a direct fit. I had to ream out the mounting holes, use a heat gun to bend the support "stalk", and file down the tab to make it fit.
    Yesterday I did the valve covers, VC gaskets, and new grommets. Hardest part was trying to keep the flaking paint out of the head. I used Honda Bond instead of RTV where the manual says, because most Honda's don't leak... I will change the oil and filter soon as a precaution. The old gaskets where leaking everywhere, hopefully this will stop that.
    New installed:
    Old Removed:
    Going to keep collecting parts and continue to replace stuff. I will sort all of these leaks some day...
    Cheers,
    Mike.
  5. #55
    Ambler, PA
    1995 540i/6
    Great work! Glad to see someone else got the CA tuned hose kit. Still have that abs laundry list to install when I am back in the states. May have an opportunity to buy a 1995 540iA over here with 60k miles (fingers crossed) and may have to search for a Dinan chip. My 6 speed is running a DUDMD chip and the difference is definitely noticeable!
  6. #56
    Nov 2020
    Oklahoma
    540i
    Quote Originally Posted by JThomp33 View Post
    Thanks! The kit seems of pretty good quality, time will I guess. If "parts car" things go accordingly my Dinan chip might be for sale in the somewhat near future.
  7. #57
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Quote Originally Posted by okmike540i View Post
    Ooh, body-matched, nice!
    You were lucky that it was just leaking. Plastic radiators often fail catastrophically, hose bungs suddenly separating from the end tanks. I highly recommend an aluminum radiator (not Mishimoto, but my CSF has been doing well so far). See the link in my sig for details.
    Mahle is usually pretty good, but considering the whole picture of Chinese industrial production, it's no surprise to me that regardless of the name on it, the result is barely usable junk. I have a good used OEM tank that's yours for shipping, if you want.
  8. #58
    Nov 2020
    Oklahoma
    540i
    I picked up some parts last week and will let you all guess what they pertain to, but this shift surround came with it... And it looked like total cracked garbage. Had some free time on my hands over the weekend so started a little project. This is semi-woodworking, but still car related.
    Sanded with 80, then 120 to get to bare wood:
    Went to my local woodcraft for some veneer and they had this "bentley" grade burl walnut. Used a japanese razor saw and a straight edge to get both edges "jointed" and then veneer taped them together in preparation for the vacuum press.
    I then taped everything up, used wax paper on my press board, applied high solids veneer glue, and sent it.
    Pretty run of the mill vacuum press, can do 2'x4' in the bag at 27 bar.
  9. #59
    Nov 2020
    Oklahoma
    540i
    Once it is out of the bag, the high solids glue will seep out of the pores of the wood and does not look great.
    I don't go crazy on the grit, starting sanding with 120 and working up to 220 until all of the glue glue blotches are gone. Then I applied shellac as a sanding sealer. To my eye, it pops the grain a bit more due to the amber color over just going to clear coat.
    After that dried, 220, then 320, then 400 by hand and it's ready for clear. I used aerosol oil based "spar" varnish from the hardware store that has UV protective additives. Here it is wet.
    And dry. I could probably be done with it at this point, but will probably sand any nibs out with 320 and rattle can a few more coats on there.
  10. #60
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    That looks better than new. The attention to detail there is great.
    Sent from my LM-V405 using Tapatalk
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯ ¯¯¯¯¯¯¯¯¯¯¯¯¯¯
  11. #61
    moroza's Avatar
    BFE
    E34T
    I like what the shifter surround suggests is the purpose of the parts stash! And it looks pretty good itself. I don't know about that surround specifically, but what I've seen of door trim is that the factory finish doesn't do the wood justice, in part because it's nearly 1mm thick. Even a stock-replicating ultrasmooth high gloss, done thinner, makes the grain much more visible. From the chemicals I've seen it resist, I'm guessing it's polyester.
  12. #62
    Aug 2019
    My oh my!
    Excellent work on that surround. Where did you pick up the vacuum pump?
    Oh… when is the 6spd going in?
  13. #63
    Nov 2020
    Oklahoma
    540i
    Quote Originally Posted by theBMWbeast View Post
    Thanks!
    Quote Originally Posted by moroza View Post
    I think you are right on it being Polyester and it is at least 1mm thick! That one panel was 10 minutes of sanding.
    Quote Originally Posted by a777fan View Post
    My oh my!
    Thanks! The pump is from a small company called VacuPress in Maine. Not the cheapest set up and I am sure one could DIY something from a refrigerant pump and clear vinyl for the bag, but a good turn key solution. Every time I veneer something I learn something new and relearn something I forgot...
    The donor was a 530, so she is only getting 5 gears. But 3 pedals is always better than 2 right? Need to order a new clutch and figure out how to go about getting the driveshaft to work. Hoping I can swap the output flange between the 540/530 shafts and be done.
  14. #64
    Aug 2019
    Thanks!
    Wow a 530 5-speed eh? I think those are actually ‘rarer’ than the 420g 6 speeds, given they were only around for 93/94/95? with the V8 bellhousing pattern.
    I’ll be curious to hear what needs to be done with the DS. I’m sure moroza or the other more experienced tinkerers here will chime in with tips.
  15. #65
    Dec 2020
    San Jose, CA, USA
    1994 "532i6", 1998 528iT
    530 is medium case (188mm) diff, 540 is large case, so unless you have the rest of the drivetrain in hand, your driveshaft needs mods. Personally I'd try to mate the front half of the 530 driveshaft to the rear half of your original 540 driveshaft, but if the splines or lengths don't work out, then just cut the 540 driveshaft to graft on the head of the 530 unit (using 530 guibo, etc).
  16. #66
    Nov 2020
    Oklahoma
    540i
    Quote Originally Posted by circuit.heart View Post
    The rear halves are completely different lengths, I was hoping that they where the same. If I can't swap the rear flange I will take it to a drive shaft shop in town and have them weld the two together then balance.
    I believe you are correct. Interestingly from what I have found the gearing is nearly the same as on the getrag, just missing the final gear at .83. Hopefully they do chime in! I think more 530i manual guys swap in 4.0's than vice versa... But you take what you can find. Found the parts about an hour from me from a guy who was parting and scrapping the car. Super cool dude, wanted it as a project but it was a little too far gone.
  17. #67
    Dec 2020
    San Jose, CA, USA
    Well yeah, that's because of the large case vs medium case differential. You do need the rear half (CSB to diff) of your stock driveshaft at the very least.
  18. #68
    Nov 2018
    Port St. Lucie Florida
    1989 535i
    That looks amazing! I have that on the list for mine, maybe doing a DIY refurb of the wood at some point.
    Your looks better than new, holy moly.
    Sent from my iPad using Tapatalk
    1989 BMW 535i - Cirrusblau/Natur, 5 speed manual. Stock and original!
    2002 Volvo C70 Coupe
    2023 Acura MDX A-Spec
  19. #69
    moroza's Avatar
    BFE
    E34T
    5-speed? You'll need a custom driveshaft. Though realistically, you wouldn't find a used 540iM driveshaft that doesn't need a rebuild anyway. 540i are unique among E34 in that the U-joint is fore of the CSB, not aft, and both components are bigger than the lesser models'. IMO, the 6-speed is worth holding out for. E39 are common junkyard fodder these days, and 540iM are much more abundant in that series than the E34 ever was.
  20. #70
    Nov 2020
    Oklahoma
    540i
    Taking what I can get for the time being. I got the whole swap "kit" for less than what most salvage yards were asking just for a getrag trans (searching on Car-part and within a 500 mile radius). If a 6 speed comes along at a good price locally, I will probably jump on it and all the other work will already be done. Oklahoma is not the cornucopia of old BMW V8's that I wish it was haha.
  21. #71
    Nov 2020
    Oklahoma
    540i
    Been a minute since the last update. Finished the shift surround. Sanded to 3000 grit, then buffed out with finishing compound. This was from an ASC car and mine is not, so I will have to figure out something to do with the switch.
    Next up, I replaced the lower control arms. They were beyond shot. I was not expecting the explosive way the ball joints pop when they decide to come loose. I still need to do the thrust arms, but they looked like they had been previously replaced.
    On higher speed lane changes when passing, the car still feels a bit twitchy after rapid wheel inputs. On slow and smooth steering input it feels fine. I am going to replace my rear subframe bushings next as it feels like the back end is a little loose. Have already replaced the dog bones. Even if that is not the fix, I am sure the rubber is degraded. Any input? I also have been getting a "ping ping" noise when driving at low speed from the back end when I go over bumps. Anyone else had this?
    In prep for the Ozark Euro rally, I buffed the hood, trunk, and roof. This really helped with some of the minor scratches and swirl marks.
  22. #72
    Nov 2020
    Oklahoma
    540i
    The car made it to and from Ozark Euro Rally with no issues. It is in Eureka Springs Arkansas the same weekend as the big VW bug fest. Bug's are not my cup of tea, but still cool seeing all of them. Went with my buds, one in his E39t and the others in some glorified beetle with no AC. The Euro Rally was probably 75% water cooled VW's and 25% everything else. All German, no exceptions. It is about a 3 hour drive from Tulsa. Here are a couple of pics:
    ^ a good spot for low point lagers.
    At Beaver Bridge after I may have passed a uniformed off duty park ranger in the double yellow.
    We did the twisties on the way there and back. I was really impressed with how well this chassis handles even with all that I still have left to replace. V8 power left the 6 pots in the back and I lost my friends more than a few times... Ended up chasing a Golf GTI most of the drive back on the pig trail, and try as he might he couldn't shake grand dads old auto beige Bimmer. Once back to Fayetteville, I reset my OBC and tried to drive like a normal person and managed some very reasonable mpg's at 75-85mph.
    Next trip is TexFest down in the hill country outside Austin. I know I will see some you guys down there.
  23. #73
    moroza's Avatar
    BFE
    E34T
    Subframe mounts? Bad news; the only good ones are genuine BMW and those have been discontinued. I would invest my efforts into tracking down a NOS pair.
    Two ideas for the shift surround:
    1. Sell yours, make another without that cutout.
    2. Get the ASC switch housing and install switches that do other things in there (got those secret hyper-jet installed yet?)
    I was recently fiddling with wood trim, struggling to find the secret to a smooth but non-glossy finish. I managed it on one piece, sort of by accident, but the others spray too grainy or orangepeely, and sanding/buffing makes them shiny. Any ideas?
  24. #74
    Nov 2020
    Oklahoma
    540i
    Noted on the mounts. I am getting the ASC housing and switch from the guy I bought everything from next time he is in town. I will come up with something for it eventually.
    Rattle can always leaves me with orange peel as well. Have you tried hitting it with 0000 steel wool? That will knock the luster off and leave a matte finish without scratching it up like wet sanding. If the peel isn't too bad it can hide that a bit too.
  25. #75
    Jan 2015
    Tempe, AZ
    1995 525i/5
    See you in Austin! I’m going for Radwood and I’ll most likely stop by Texfest as well.
    Not a fan of the Powerflex poly subframe bushings? I’ve seen them on a lot of cars and they’ve held up quite well with no noticeable increase in NVH.
    1995 525i 5-speed - Thread
  1. FS: 1995 540i/6 - Green/Beige - FL - $4700
    By timmyg7 in forum BMW Cars For Sale / Wanted
    Last Post: 07-13-2007, 03:50 PM
  2. 1995 540i 91k in SoCal
    By RedV in forum BMW Cars For Sale / Wanted
    Last Post: 03-08-2004, 08:39 PM
  3. 1995 540i 6 speed
    By mkiv98 in forum 1988 - 1996 (E34)
    Last Post: 01-02-2004, 02:02 AM
  4. 1995 540i For Sale $12,700
    By 540ibeast in forum 1988 - 1996 (E34)
    Last Post: 10-20-2003, 02:03 PM
  5. FS-1995 540is 6-speed
    By T///MW in forum BMW Parts For Sale
    Last Post: 10-12-2001, 03:47 PM
