Please do not hate on my post. I am new here. Could not find a definitive answer.
Is the M5 differential the one that is finned?
Is the regular diff on a 540 finned?
Is the Dinan diff finned?
I went under the car for the first time to change all fluids and I think the previous owner put in an LSD.
Please let me know!
Pics would be awesome.
Thank you!
Factory diff is not finned. Only m5 has a finned diff.
Sent from my SM-G973U using Tapatalk
I'll be home tonight. I'll post a picture of my stock open diff.
The Dinan and stock M5 diffs are both finned.
The Dinan M5 is the cleaner one, dirty is stock M5.
95 Pontiac Bonneville SLE
97 528i
98 Infiniti vq35'd i30: 13.3@104mph, 30MPG Hwy (RIP)
02 Jag X-type
03 M5
07 Ducati Monster S2R 800 with DS1000 swap
83 Yamaha IT175K
72 Yamaha DS7: '74 RD250 swap, JL chambers
Looks like my reply did not post. Thank you guys!!!
Looks to be there is no difference in the numbers stamped on the side.
I can probably do some digging from here. But this really helped.
Thanks again
If you jack up the rear and turn either wheel the other wheel will turn in the same direction if you have an LSD diff.
If it turns in the opposite direction it isn’t an LSD.
A non LSD diff housing can be fitted with an aftermarket LSD and still retain the non finned rear cover.
Jimlev to the rescue with basic mechanical knowledge. Thank you good sir.
