<iframe width="560" height="315" src="https://www.youtube.com/embed/PxE3sU-5WnQ" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
https://www.youtube.com/watch?v=PxE3sU-5WnQ
PSA: Reminder to lube hood latches springs
Reminder to open your hood and lube it at least once a year.
Went to close the hood, and noticed it wasn’t latching correctly.
One of the hinges was rusted frozen
Soaked it with Liquid Wrench and worked it free with a screwdriver.
E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
You'd be much worse off if it rusted frozen with the hood closed! I've dealt with that a few times. Not fun!
I lube all the hinges and latches probably every 6 months, works like butter
Any particular spray recommended? So many different ones these days. White grease etc etc I mix them all up.
I use zep 45 and a small brush with red line grease for door latches
