Stuff to do on a one piece iX rear driveshaft. Note that even though you'll do a rebalance, mark the sections for reassembly in the same position.
Centering sleeve (26117526611) - this is a piece of rubber that goes in the front tip of the driveshaft. The old one may not need replacing but the part is cheap enough. I'd add this to your list if you're doing a full refurbishment. It is a PITA. I think I had to burn the old one out.
Threaded ring with clamp ring (26117514037) - this is the big nut you loosen to collapse the driveshaft and the internal compressible sleeve that has likely turned to jelly. It comes as a kit, but all you'll use is the compressible sleeve. The nut is for a 2 piece driveshaft. You reuse the toothed gear. Inside the rear shroud is a dust seal ring. I've never found a part number for it so you'll reuse that too.
Service
U-joint - see if you have a local driveshaft service company. Have them do the driveshaft and rebalance.
Assembly
Guibo/Flex disk - you can reuse the bolts, but replace the 6 locknuts (07129964672)
In back I'd replace all 4 bolts (26111206718) and locknuts (07129964672)
When you're trying to collapse the driveshaft, the big nut you have to loosen looks like it's threaded into the tailpiece and you'll think you want to turn it CCW looking from front to back. It's actually threaded on the front piece so it's CCW looking from back to front.
Here's a link to a photo album with some iX driveshaft pics in it. https://photos.app.*******/SCyohcc6sRJDRX2dA
"Howdy, Folks!"
