Help,
my bmw 116 i was down in the garage for a few weeks for some maintenance. I got the car back today and realize the overhead light, the hazard light the power windows, the powered side mirrors are all not working - also the headlights are constantly on when the car is running or ignition on. This was not so before. Also fog light not coming on.
It would seem this has something with removing the battery after it became discharged and replacing after it was recharged.
Any help would greatly be appreciated.
Robin
8686896338
Take the car back to the shop and have the shop properly charge the new battery. Batteries sit on the shelf for months before they are installed. As a result they tend to be down on power. Also, make sure the shop “registers” the battery with car’s intelligent charging system. Otherwise the charging system will overcharge the new battery.
The battery must be registered with the car when they are replaced with anything other than the EXACT specs of the battery which came out of it. Any European shop who works on current BMWs should know this. It must be coded through the dealer or you can do this yourself if you use a bluetooth OBD scanner and phone app. Personally, I use OBDLINK MX+ and the Bimmercode or Bimmerlink app.
About the lights staying on... Did someone use another car to jump start your BMW? If this is the case, you could have blown a module and those can get expensive. Ive had this happen to a 528i.
I DO NOT ever use other cars to jump mine. BMWs arent immune to frying electronics this way. I only use batteries that are charged to start the car. If its dead, charge it first or get another battery. My lesson was learned the hard way.
The windows and sunroof have to relearn for the anti-pinch function. Normally you just have to lower the window all the way down and then all the way back up again. Repeat for the other windows and sunroof.
Current lineup: 99 BMW M3vert (project) , 05 Mazda RX-8, 04 Mercedes CLK320, 03 Chevy Express 1500 (work van).
Previous rides: 07 Mazda RX-8, 92 BMW 325iNV, 94 BMW 325iC, 94 BMW 325i S50 M3 clone, 84 Mitsubishi Cordia Turbo, 84 Mazda B2000 lowrider, 88 Toyota Tercel, 88 Honda Accord, 93 BMW 318i, 95 Nissan Altima, 89 Toyota Camry, 95 Mitsubishi Eclipse GS-T, 93 BMW 318is, 84 Toyota Tercel, 96 Mitsubishi Eclipse GS-T, 97 BMW 528i 1JZ swap, 94 Acura Integra 4dr, 88 Toyota Corolla Wagon, 97 VW Jetta GLS, 86 Toyota Corolla AE86 4A-GZE supercharged engine swap, 94 Lexus LS400, 95 Isuzu NPR Turbo, 01 Suzuki TL1000R, 98 Honda CBR600F3, 99 Yamaha R6 and countless other dirt bikes and toys
Thank you very much for your comprehensive reply. And yes it was battery related. The footwell module was blown. It's expensive to replace.
Thanks a mil.
Robindra Bujhawan
