$Sold.
Located in Boston, MA
1997 M3 Black
Pictures: https://imgur.com/gallery/MzRR2xo
138,663 miles
Clean title. Last Registered/Inspected in MA in 2018
This car was primarily used as a track car. High quality parts were always used and new hardware was purchased anytime something was worked on. All old hardware and sensors pulled off were cleaned and kept as spares (included in sale).
Shock towers and RTAB pockets are rust free and in good shape. There was minor rust at the front jack points which was cleaned with a wire wheel, inspected, and primed/painted with POR-15 to protect it from further damage.
The body is not in perfect condition, there are scratches and chips. The Hood and Left front fender are not original to the car. They are painted with the correct color code but do not match exactly. There is a small rust spot on the rear tail panel shown in pictures.
Comes with spare hardware, sensors, rear trailing arms, front control arms, subframes, etc.
All parts listed below were replaced within the last 1500 miles.
I have a detailed maintenance and modification documentation available.
Suspension:
MCS 1way Non Remote shocks
Hypercoil 700F/800R springs
Anti Spring Bind Kit Bimmerworld
MCS Adjustable front endlinks
Vorshlag Camber/Caster plates
AKG Rear shock mounts
Adjustable rear camber arms Turner Motorsports
RTAB reinforcement plates (AKG plates, Welded by Wile Motorsports)
75D Poly RTABs, Rear Diff Bushing, Rear Subframe bushing, & FCABs
Rear shock tower reinforcement plates Bimmerworld
X-brace
AKG Front subframe reinforcement
Full overhaul of suspension
Control arms, ball joints, bushings, bearing, eccentric bolts, etc - All genuine BMW
Wheels
Apex ARC-8 17x9 ET42 Wheels in GREAT condition no scratches. Mounted with 225/45/17 BFG R1-S ~8 heat cycles but from 2017
Stock DS2 Wheels in good shape - Mounted with 235/40/17 Dunlop Direzza ZII. Good tread left on these, driven on the street and used on track in the rain
Engine/Drivetrain
DiffsOnline 3.73 Diff
Rebuilt Head
Genuine BMW Head Gasket
Rebuilt VANOS
ARP Head Studs
Genuine Valve Cover Gasket
Completely overhauled cooling system
Stewart Waterpump
CSF Performance Radiator
All new hoses
M50 intake Manifold
3.5 Bosch MAF
EPIC tune (Engine Calibration Interface included)
Euro Coolant Tank Conversion
VAC Oil pan baffle
Safety wired oil pump nut
Bimmerworld Race Intake
Rebuilt Driveshaft Beyer Motorworks
Bimmerworld Group N Motor mounts
Rogue Transmission mounts
Rear Diff Bushing AKG 75D Poly
AKG DSSR
Safety:
4point bolt in roll bar Bens Bar
Cobra Evolution Seat (Drivers Side)
Cobra Monaco Pro Seat (Passenger Side)
Seats mounted on VAC mounting brackets
Eye bolts for harnesses use either factory threaded connections or installed with 4 plates
Expired Scroth belts (used in HPDE car only)
Stainless braided brake and clutch lines
OMP 350mm steering wheel with NRG hub
Other:
ZHP Steering rack Rack Doctor
Fully rebuilt Power Steering (lines, reservoir, cooler) Genuine BMW parts
Dual Fuel Pumps Bimmerworld kit
Injectors cleaned Marren
Fan Clutch and Fan Genuine BMW
CCV replaced Genuine BMW
Carbon Fiber Sunroof Delete
Motion Motorsports front underpanel
Hard Motorsports brake ducting plates
Carbon Fiber Sunroof Plug (Bimmerworld)
Stainless Brake/Clutch lines
PFC-08 brake pads
New Windshield
AAF Floor Plate
Such a good price/car for the money. I wish i could buy it.
Sold.
