Results 1 to 10 of 10
Thread: Vacuum advance for distributor
    Jun 2017
    los angeles
    e21 320i
    Does anyone know where to get a new vaccum advance mechanism for a 79 320i us version? I see some similar looking ones from pertronix but was wondering if anyone had a part number they used. Thanks
    Dec 2016
    Atlanta Ga
    98 M3 Sedan, 82 320i
    I'm in the same boat but for an 82 320i 12111288446 or 12111705915, cross ref from later e30 m10. Did the suction test this weekend no vacuum so diaphragm is mot likely cracked, the distributor advance can be freely moved by hand but doesn't move during suction test.
    Dec 2016
    Atlanta Ga
    Ordered one from this source looks like the same part, other threads on this subject lead me to this, thanks.
    Looks straight forward
    https://www.ebay.com/itm/BOSCH-Ignit...72.m2749.l2649
    Dec 2016
    Atlanta Ga
    Got the vacuum advance in the mail finally. My vacuum advance was stuck i used wd40 to unstick it installed new advance mechanism and now it works. Probably check timing, still get 1400rpm idle which has been their since I've owned the car. The car runs great except the high idle, maybe someone advanced the timing years ago, the car has run excellent at all speeds with the advance broken.
    Mercer Island, WA
    88 325iC,'11ML350,'84RX7
    Have you tried adjusting the idle screw by turning it clockwise (someone correct me if I have it backwards) to lower the idle? If it is all the way in and you are still at 1400, then there is a vacuum leak somewhere...
    Dec 2016
    Atlanta Ga
    Timing is good 25 btdc @2200, new vacuum advance gives 10 degree's @ 2200 rpm. Don't think I have vacuum leaks car stalls when dip stick is pulled, no hesitation at any speed pulls hard. Turning manifold screw only seems to change the mixture. I'll go back thru O2 sensor, 2 years old, idle drops 200 rpm when disconnected.
    Dec 2016
    Atlanta Ga
    New O2 sensor installed for good measure, adjusted the manifold screw in around 3/4 and redid mixture too around .70 vdc ish (very finicky) with O2 disconnected, swings between .10 - .80 vdc connected. Idle down to around 1100 with or without O2 connected, runs good. think I may have to pull WUR and check i out, cold idle is about the same as warm, but no problem staring cold. Vacuum advance makes a difference in the power band, the original problem, guess everything is related as usual.
    Jan 2019
    Washington, DC
    95 Spec 3, 83 320i, 128i
    Quote Originally Posted by 82Kashmir View Post
    Pull the idle adjustment screw all the way out (with the car off) and inspect the threads and the o ring on it. Clean and replace and see if you can get your idle down to 850. My idle screw was super gross and replacing the seal fixed my high idle.
    Feb 2009
    District Nine
    sold 78 BMW 320i
    The manifold screw?
    If you are referencing the idle speed screw on the throttle body, this does not affect the air/fuel ratio, maybe the o-ring is bad. This idle speed screw is on a 'metered air' passage.
    Note: there is a rubber plug on a vacuum nipple on the underside of the intake manifold. Make sure this is good too.
    Quote Originally Posted by SenorTaylor View Post
    Yes, do this
    Tbd
    Dec 2016
    Atlanta Ga
    Will do, along with pulling the WUR and cleaning, however seems to be running good and slightly higher idle is good for the auto/ AC this car came with.
  1. Source for distributor vacuum advance unit?
    By alpinewhite318i in forum 1975 - 1983 (E21)
    Last Post: 10-18-2020, 10:40 AM
  2. Replacing vacuum advance mechanism on distributor
    By e21Luis in forum 1975 - 1983 (E21)
    Last Post: 05-05-2020, 08:55 AM
  3. 1979 320i Distributor/ vacuum advance prob.
    By rharold51 in forum 1975 - 1983 (E21)
    Last Post: 09-27-2008, 11:25 AM
  4. WTB Vacuum Advance 1974 02
    By Zender in forum 2002
    Last Post: 08-24-2008, 03:06 PM
  5. What year is my motor? Vacuum Advance?
    By Houpty GT in forum 2002
    Last Post: 10-26-2006, 09:56 AM
