Results 1 to 6 of 6
Thread: e36 Toeing in & out or swaying with bumps in road HELP!
    Jun 2020
    Houston
    94 E36
    Almost doesn't matter the speed at all. Usually as I go over a bump it feels like I'm driving on a cement road full of rocks...
    The car has a "wheel hop" feeling & skips at worst & at best I can feel the rear of the car "steering" & the settling
    My subframe bushings appear to be good could it be the diff bushings?
    My e36 has AKG Delrin RTABS & I can hear when those bind as it makes a distinctive sound It's not those
    I also have DriftHQ toe arms which are brand new & my bolts are tight/snug (I checked)
    I recently swapped out my subframe as my old one had a bolt seized in it & the problem began after the subframe swap.
    Sure my common since says subframe bushings, but I highly doubt that's the issue as the car only really pulls to the right if anything...
    It feels about the same as when my RTABS were bad. I'd say 30% of what those felt like at their worst & they were metal to metal clanking when I got the car.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved from E36 common problem and DIY fixes forum to E36 forum.
    Jun 2010
    NY
    1997 328i
    Get an alignment make sure the shop understands how to do rear toe.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    You report, "my car worked until I fixed it, now it doesn't work." I think you need to get under the car and check your work.
    Jun 2020
    Houston
    94 E36
    JdHaggle-Land I need an educated opinion on the source so I don’t replace more than I need to.
    I gave detail on what was fixed & made sure to note the I rechecked all my bolts that were touched (indirectly) sure an idiot can change the subframe but most wouldn’t attempt.
    You’re the reason people don’t like forums.
    & I never said the car “worked” until I fixed it you trying to be a smartass told you I said that.
    I said a bolt was seized in the last subframe, BUUUUUT I’ll let you assume & not explain how I knew it was (seized/crossthreaded) or why I was “fixing” it in the first place since you like jumping to conclusions.
    Jun 2020
    Houston
    94 E36
    Eric I’ll try that first I know these bmws are iffy... I had a bad rear tire (had a nail in it) & it made the steering wheel not straight. Any other car would’ve drove straight
  1. E36 Eibach e36 M or non-M front sway bar and poly bushings
    By M3Rob95 in forum Suspensions, Springs & Shocks
    Last Post: 10-24-2011, 07:20 PM
  2. E36 E36 M3 or non-M Front Sway Bar and poly bushings
    Last Post: 10-16-2011, 05:57 PM
  3. E36 E36 M3 Dinan front and rear sways with bushings and links
    By E30Alpina in forum Suspensions, Springs & Shocks
    Last Post: 08-11-2011, 08:06 AM
  4. E36 FS: E36 m3 struts, springs, calipers, rotors, sway bars. San Jose/Bay area
    By craiggroves91 in forum Suspensions, Springs & Shocks
    Last Post: 06-17-2011, 05:52 PM
  5. E36 m3 e36 H&R springs and stock sway bars
    By jj97m3 in forum Suspensions, Springs & Shocks
    Last Post: 05-13-2010, 09:25 PM
