eBMWParts
Results 1 to 1 of 1
Thread: suspension problem
    Nov 2020
    ky
    2008 bmw x5
    suspension problem
    2008 bmw x 5, I converted the rear airbags to coil springs, Have any of you did this and had the problem below.
    this is what i sent the seller of the springs
    These are the 2 photos from yesterday after an attempted alignment, The tires were out so much looked like an overloaded Volkswagen,
    The alignment shop said they could not be alignment because they were out so much they could not be aligned so all he could do is adjust the camber to the max and that did not bring the tires in enough to correct the problem these spring made
    I want a new set of springs to fix this issue, not the same springs but longer spring and
    Otis
    http:www.gtmustangs.com/bmw2.jpg
    http:www.gtmustangs.com/bmw.jpg
    http:www.gtmustangs.com/s-l1600.jpg
    Bought the kit off ebay
  1. E36 Suspension Problem
    By msellman in forum 1991 - 1999 (E36)
    Last Post: 05-21-2006, 11:04 AM
  2. Common suspension problems?
    By inf0strada in forum 1992 - 1999 M3 (E36)
    Last Post: 12-25-2002, 05:53 AM
  3. 2002 330CiC Suspension Problems
    By ///MDriver in forum 1999 - 2006 (E46)
    Last Post: 06-11-2002, 12:06 AM
  4. suspension problem ?! tires ? transmission ?
    By bimmerforce in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-16-2002, 06:49 PM
  5. H&R/Bilstein suspension problem
    By 320 in forum 1991 - 1999 (E36)
    Last Post: 09-26-2001, 05:28 AM
