95 BMW 325i Sedan - Built for dual street/track duty.
176k miles - 100% stock motor/trans
5 speed
16" M-sport wheels w/Conti DWS tires
Clean PA title in hand
This car was purchased in 2014 and the build was mostly completed in 2015, with a few tweaks in 2016. The car was run in only a handful of HPDE's and one TT event at the end of the 2015 season, where it broke the track record in TTE by over 1 second. I've had the car at the track only once (September of this year) since the last event in 2016. Rather than have this collecting dust in my garage, I am putting it up for sale. I recently had the car inspected and serviced, so it is fresh and ready for the next driver to enjoy.
Everything original has been replaced with new OEM parts! This car is ready for w2w, just needs safety equipment (cage, seat/harness, fire) and a pilot.
The Good:
-Inspected until 09/21.
-Everything works: ABS, power windows, power/heated seats, cruise, radio, sunroof and full leather interior
-Perfect dual duty street/track car - has ALL the structural mods needed for track, just add driver and go.
-Excellent condition for a 25 year old car.
The bad:
-rust bubbles starting to form on the rocker and fender.
-headliner & A-pillar cover removed
-glove box cover needs to be glued
-AC removed
Reinforcements/misc:
AKG welded RTA (rear trailing arm) pocket reinforcements plates
AKG welded front subframe reinforcement plates
AKG welded rear sway bar reinforcement plates
AKG welded rear subframe reinforcement plates for chassis
AKG bolt-on rear shock tower reinforcement plates (upper)
AKG 75D engine mounts
AKG 75D trans mounts
AKG 75D diff bushings (2x rear cover/1x front)
AKG 75D rear trailing arm bushings
AKG 75D rear subframe bushings
AKG 75D front lollipop bushing (centered)
VAC safety wire oil pump nut
Bimmerworld welded aluminum oil pan baffle kit
Z3 reinforced oil pickup tube
Bimmerworld magnetic drain plug
Brakes/suspension:
rebuilt OEM front calipers (NIB spare seals inc.)
rebuilt OEM rear calipers (NIB spare seals inc.)
New Zimmerman vented rotors (front, NIB spares inc.)
New Zimmerman solid rotors (rear, NIB spares inc)
HAWK DTC-60 pads front (NIB spares inc)
HAWK DTC-60 pads rear (NIB spares inc)
ECS SS brake line set (6 line)
ECS brass caliper bushings
Wheel stud kit F&R
OEM BMW front shock tower reinforcement plates (notched for GC camber plates)
Ground control coil over suspension (F:single adjustable Koni's, R: HR springs GC jackers & struts)
Ground control race camber/caster plates
*New Meyle tie rod ends 9/20
*New RackDoctor.net steering rack 9/20
*Fresh alignment 9/20 (3.2* camber front / 1.8* camber rear w/ 1/32nd toe-out front and zero toe rear)
Driveline:
3.91 LSD w/4 disc clutch setup, zero preload & OEM 45* ramp rates
Z3 short shifter
Misc Electrical & Fluids:
*New Battery 09/20
*New ABS sensors 9/20
*New Knock sensor #2 9/20 (NIB spare inc.)
*New TPS 9/20
Additional pics and info available to serious buyers.
Price is $7,500.00 obo, not interested in any trades what so ever!
Please email mcantor78@gmail.com with HPDE in the title for fastest response.
Perfect for NASA Spec3!
