Results 1 to 11 of 11
Thread: E31 M70 motronic 1.7 MOSFET reference needed
    Mar 2020
    Le Mans, France
    1991 850i individual
    Hi
    I got an issue on one of the DME motronic 1.7 of my 1991 E31 M70.
    Smoke was going out from one of the DME and also the corresponding coil was smoking.....
    I have open the DME, found a burned MOSFET, but i was not able to find the reference of this components on the web.
    I suppose it was a internal BOSCH reference. Does someone know a compatible MOSFET reference i can use ?
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Bad coils will do that.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Mar 2020
    Le Mans, France
    @rjjablo Thanks for the link, but i am looking for the MOSFET reference only
    Quote Originally Posted by TxGR8White View Post
    Yes i confirm,, the coil is dead.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    for the replacement for that driver,
    Ask EEDegreeToDrive
    '91 850i 6sp (mint) (sold)
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    There's oodles of equivalents - but TIP 162 worked for me:
    https://uk.farnell.com/multicomp/tip...295?ost=tip162
    ...or on Amazon:
    https://amzn.to/3f3FGtM
    Same as used on the V8's: https://www.meeknet.co.uk/E32/ECU/Index.htm
    My BMW Repair YouTube Channel
    Mar 2020
    Le Mans, France
    Ok thanks for the MOSFET reference Timm.
    Mar 2020
    Le Mans, France
    Hi
    I received the new MOSFET, but its form factor need to be "tuned" to put it back in place inside the DME.
    The M70 is now running on 12 cylinders !
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Well done! Yes, I had to do the same on my M60 - nothing a file won't sort out!
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Not that it matters much for you as you have resolved the problem.
    But for those that are electronics professionals.
    The correct device type is everything in identifying the appropriate substitute device.
    See attached document.
    The device is not a MOSFET it is a NPN Darlington Power Transistor - SOT-93 package with the heatsink tab removed.
    My only suggestion in selecting a substitute is to make sure the back of the device looks the same as many devices have changed the package configuration over the years and the power dissipation ratings can be lower.
    I anticipate the original DME device has bare metal exposed on the back side for best heat dissipation to the heat sink.
    Some of the newer devices will be completely enclosed in plastic and hence the power rating is compromised.
    Also, make sure a heatsink compound is applied to the back of the device in contact with the heatsink.
    The heatsink compound substantially increases the heat transfer and thermal dissipation keeping the transistor cooler.
    Attached Files Attached Files
    Nov 2015
    Ger
    E31 850iA 1992
    hese are special BOSCH transistors.
    ...buy a cheap DME (E30, E36...) and put that transistor to your DME.
  1. E31 Need E31 M70 dual fuel pump cradle assembly
    By pumpedTSI in forum Parts for Sale
    Last Post: 11-07-2021, 10:42 PM
  2. E31 E31 & M70 parts
    By M.Rad. in forum Parts for Sale
    Last Post: 02-18-2014, 10:21 PM
  3. e31 M70 twin turbo manifolds
    By sausrigging in forum Forced Induction
    Last Post: 08-14-2007, 02:30 AM
  4. Quick maintenance reference needed
    By Barabba in forum 1991 - 1999 (E36)
    Last Post: 11-14-2006, 06:09 PM
  5. Orange County alignment shop referal needed
    By hamanncheese in forum California sponsored by Avus Autosport
    Last Post: 05-06-2005, 04:53 PM
