Results 1 to 4 of 4
Thread: Code U118A
    Nov 2020
    Spring Hill Florida
    2013 BMW X1
    Code U118A
    Need advice regards a U118A code coming up on a 2013 X1 2.8i AWD automatic with 77k please. Has service engine soon light on
    Jul 2003
    Spring, TX
    E36 328is, E39 M5
    U118A relates to the ABS and DSC... check any fuses that are ABS/DSC related and hopefully that solves it.
    Lime Rock Park... the most fun you can have in a mile and a half.
    Aug 2023
    Ottawa.on
    E84 f90
    Did you find the issue?
    Aug 2023
    Ottawa.on
    E84 f90
    I am having the same issue after replacing corroded ground cable on my e84. Only 1 code u118a. awd, dsc, abs, and brake light on . Tested wheel sensors and all were good.Tested the ground connection for abs module. Tested all related fuses and no luck. I don't have comfort access and I drive.
  1. Built in Fault Code Reader!!
    By Mike325i in forum 1991 - 1999 (E36)
    Last Post: 08-23-2001, 08:36 PM
  2. need help finding out radio CODE!!!!
    By 232is PoWeR in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-17-2001, 12:33 AM
  3. WTB: Peake Research Fault Code reader w/ manual
    By Lopaka in forum BMW Parts Wanted
    Last Post: 06-29-2001, 01:46 AM
  4. DME fault code: EGO Sensor #1??
    By ///Arman in forum 1991 - 1999 (E36)
    Last Post: 05-29-2001, 07:56 PM
  5. Radio..."Code Wait"
    By JCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2001, 01:59 AM
