I do not drive this car a lot and wish to do other things with the potential capital it could raise.
The information that I know of the car:
Miles: 135,850
Price: $28,000
Modifications:
- GT30R Turbo
- Tuned by Frank Smith
- 42 lb injectors
- Active Autowerke manifold
- CES cut ring headgasket
- CES copper spacer
- ARP head studs
- Dinan exhaust
- H&R Springs
- Bilstein shocks
- S54 rear differential
- SSR GT3 wheels
- Michelin pilot sports
- 305/30/19 rear
- 235/30/19 front
- Magnetic stone guards
- Upgraded stereo with subwoofer
- M50 manifold conversion
Maintenance:
- Detent pin kit
- CES Cut Ring Headgasket Copper Spacer Combo BMW E36
- Item# hgspacercombo1 Select Bore Size: 86.4mm up to 87mm Bore S50/52 Motor
- BMW Exhaust Manifold Stud
- BMW Intake Manifold Gasket
- BMW Throttle Body Gasket
- BMW Timing Chain Lower
- BMW Timing Chain Guide
- BMW Timing Cover Gasket
- Audi VW Oil Drain Plug Gasket
- BMW VANOS Sealing Gasket
- BMW VANOS Access Plug
- BMW Crankshaft Seal
- BMW Flywheel Bolt
- BMW Clutch Pressure Plate Bolt (8x16mm)
- BMW Clutch Pilot Bearing
- BMW Clutch Release Bearing
- BMW Clutch Alignment Tool
- BMW Oil Pan Gasket
- M50 manifold
- S54 rear differential gasket
- R1 1997-2002 BMW Z3 Front Rear Drill/Slot Brake Rotors+Ceramic Brake Pads
- Weighted shift knob
- FX STAGE 3 CLUTCH KIT + CHROMOLY FLYWHEEL
- A/C seal and gasket rebuild kit
Here is a YouTube video on a walk around and a couple of pulls:
Walk Around:
https://youtu.be/YbK27XkgCY4
Pulls:
https://www.youtube.com/watch?v=xYNFromiUA8
Website made with many more pictures:
https://natesautocollection.wixsite.com/99mcoupe
Lots of upgrades and reciepts.
Just did cutring headgasket and copper spacer. Complete cooling system refresh. New clutch and flywheel. Shifter detents replaced. S54 rear diff with new gasket. H&R + bilstein.
This is a drivers car and not a museum piece. Please make sure to watch the video for detailed information
No joy rides.
How much?
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
Is car in michigan or texas?
