Results 1 to 3 of 3
Thread: Running an M50 on an MS 41.1 ECU
    Aug 2020
    Saratoga NY
    looking
    Ill spare the details but bottom line is I'm looking to run an M50 in a 98 318 and I need to retain the functionality of the OBD 2 port (for emissions). Can the M50 be run off a stock MS 41.1 ECU (provided it has an EWS and SAP delete)?
    Aug 2020
    Saratoga NY
    looking
    Bump, still looking for answers but I think a 323 ECU should do the trick with an 323 harness. Can anyone confirm this?
    May 2017
    Owings, Md
    1998 328i
    Quote Originally Posted by scavone View Post
    You can do it but will need the m52 euro crank sensor that is mounted on the timing cover like the m50 uses but it is a different type of sensor (hall versus induced current or something along those lines). You will need the m52 engine harness.
  1. Replies: 6
    Last Post: 09-24-2020, 08:43 PM
  2. Fs: Ms 41.1 dme / ecu m3
    By dmb882 in forum Engines, Performance Parts & Software
    Last Post: 10-21-2012, 04:25 PM
  3. M50 Non-VANOS Complete w/ ECU from E34!
    By Wiseguy ON in forum BMW Parts For Sale
    Last Post: 09-06-2006, 11:49 PM
  4. Anyone here ever run a low compression motor on stock ECU?
    By ADVANT123 in forum Forced Induction
    Last Post: 02-09-2006, 10:25 AM
  5. Rough running with M50 on OBDII any solutions?
    By BGM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-16-2003, 01:27 PM
