Results 1 to 4 of 4
Thread: E30 Suspension Gas or Oil Pressure Shocks replacement
    Nov 2020
    London, UK
    1988 BMW 320i Cab E30
    Hi everyone,
    New to the threads here, i have a BMW 320i auto Cabriolet E30 and i need to replace the front shock absorbers as the near side shock has failed leaking oil!
    Would you recommend sticking with oil pressure shocks or change to gas pressure shocks? If going with gas pressure shocks, would i still need to fill the tube with oil for lubrication to minimise corrosion.
    I want to maintain stock ride height as this is UK and potholes are a plenty all around.
    Many thanks all
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    for regular use, I would just go with whatever was in there if you have not had trouble with them.
    No e30s again.
    Dec 2014
    Canada
    72 2002tii 97 M3 87 325i
    Replacement shocks
    Quote Originally Posted by Jdarts87 View Post
    Hi everyone,
    Many thanks all
    I recently changed my OE shocks on my 87 vert. I went with Bilstiens, a little more expensive than oe shocks but I really like the ride, and handling. The higher pressure keeps wheels on the road and smooths out those pot holes and bumps. No need to lubricate..
    Dec 2005
    No e30s, again :(
    funny, I just did the fronts on my son's superE. we just got kyb gas struts for it since he is in basic training and we don't even know if he is going to be stationed here in the states. if he goes here in the states, I wanted to the car to be fairly stock so its easy to work on in case he has trouble anywhere he gets stationed
    No e30s again.
  1. Oil light flicker. Oil Pressure Switch replaced.
    By tEckniks in forum 1992 - 1999 M3 (E36)
    Last Post: 08-24-2015, 11:12 PM
  2. 545i oil pressure switch replacement
    By matthewt in forum 2004-2010 (E60,E61)
    Last Post: 10-12-2014, 01:09 AM
  3. Suspension Leveling and Oil Pressure Switch code?
    By HOOD RICK in forum 1988 - 1996 (E34)
    Last Post: 10-03-2010, 01:01 PM
  4. E30 E30 VDO Gauge Kit - Oil Pressure, Temp, Volts
    By Guerc in forum Engines, Performance Parts & Software
    Last Post: 09-04-2010, 08:59 PM
  5. 1986 528e Oil Pressure Switch Replacement
    By indigowhale in forum 1982 - 1988 (E28)
    Last Post: 09-07-2006, 10:23 AM
