Im hoping there will be someone here who might be able to help me out
I was driving down the motorway at 70mph on cruise control at 12am when the car out of nowhere came gradually to a stop leaving me stranded. The car would start fine but only rev up to 1500 rpm in nuteral. The car could not and would not drive at all. Not even to 1 or 2 or 5 mph. I got it towed back home. Apparantly the aa said it was the turbo that had gone. I left it parked on my drive for a few months. A couple of weeks ago i fully charged the battery (its a new battery less than 6 months old) and when i fired it up, you could tell it was struggling to start, and when it eventually did, now it would struggle to even rev up to 1000rpm. Now today i bought a friend around to show him and get his opinion on the matter, the worst has happend. The car will not start at all. Please keep in mind the battery is completely fine and fully charged. I put the key in and press the start stop button. Car struggles to start but does fire up - 4/5 seconds pass by and it dies. Tryed to start it again and did with only 5 seconds later it cutting out on me again. To think things couldnt possibly get any worse. Now the car refuses to start. It cranks and cranks. It did fire up one more mere time but as soon as i took my foot off of the clutch it gave me the finger. When its trying to start you can hear the engine giving everything its got but theres some evil lurking there holding it back. Any ideas? Thank you and much appriciated 🙏
SES? Pulled codes?
Are you gonna eat that?
Hi people. I have got the codes pulled for the vehicle but i have no idea what they mean. I will put the report here and if anyone can shed some light on what they mean in simple terms it would be appriciated :-)
Found the following fault code/s:System : Engine control 1 - 1LE / Diesel EDC 16C(P)3544CC - Boost pressure actuator. Error Message : Component defective.4212 - Glow plug, cylinder 1. Error Message : Open circuit.4222 - Glow plug, cylinder 2. Error Message : Open circuit.4242 - Glow plug, cylinder 4. Error Message : Open circuit.4A27 - Generator load. Error Message : Signal faulty.4BC2 - Hot-film air mass meter. Error Message : Open circuit/earth/positive short.4BC7 - IAT sensor. Error Message : Open circuit/earth/positive short.4BA1 - IAT sensor. Error Message : Signal too low.Member advised vehicle cranks but will not start.Bosch diagnostics. Actual data on fuel pressure, air flow and engine speed. All readings as normal. Injector switching ok. Checked EGR valve. Member wishes to arrange repairs himself. Engine Oil Level Ok. Coolant Level Ok.
Thank you again
