Took the E36 M3 Turbo for the first time to the track a few weeks ago.
I noticed on hard turns while carrying speed through a turn, the car would bog. But once it straightens out, then the issue goes away. This happened with roughly 1/2 tank of gas.
The fuel pump is a Walbro 535 using the original hanger.
Any suggestions on how to combat this issue? Do we need a baffle of some sort?
Thank You
Right hand turn? You need a second fuel pump. There are several solutions. Search e36 dual fuel pumps.
I know right hand turn for sure. But not 100% sure of left hand turns but I think it did occur on both sides.
Thanks for the link. Will look into it.
It's a common problem. My S50 is supercharged and I use an Aeromotive 340LPH pump, but I get the same starvation with anything less than 1/2 tank.
It's caused by the design of the saddle tank. Most commonly occurs in long-ish right hand turns at ohhhh around 1G or more.
You need a pump in both sides and some additional plumbing, or a surge tank.
There is a thread on the same subject 20 entries down:
https://www.bimmerforums.com/forum/s...iphon-Pump-Kit
This might sound dumb, but I was just reading a thread where someone had a loose intake boot and during high G turns it would move and let unmetered air into the intake which caused loss of power.
Fuel cut has a very distinctive feel to it and will only happen in high G right handers. Not saying it's not fuel related but might be worth checking all your house clamps and vacuum hoses first.
I just run a surge tank, works flawlessly down to next to no fuel in the main tank. Bit of extra expense but worth it I think.
Thanks man. The system was pressure tested and no leaks were found. Besides a loose intake boot as you mentioned would blow right off even when not in boost.
I don't have a build thread (should have created one), but here is a list:
Motor
S52
J.E. Pistons 87mm Bore
ACL Race Bearings
Supertech Rods
Supertech Valvetrain
ARP Hardware
Stock S52 cams
Cut-Ring Headgasket
SPA Turbo Manifold
M50 Intake Manifold
Clutch
DKM Twin Disc
Transmission
Stock 5 speed
Stock M3 LSD
Fuel Setup
ID1050x injectors
Walbro 535 Fuel Pump
APE - Flex Fuel Kit
Turbo
Garrett GTX3076r GEN2 (upgrading to the new Garrett G35-900 over the winter)
TIAL External Wastegate - 15lb spring
TurboSmart Race Port BOV
AEM TruBoost - Boost Controller
AEM Wideband
Cooling
Treadstone Performance Intercooler - TR1035
Grassroots Performance Oil Cooler
AEM Methanol Injection
Koyo Radiator
16" SPAL Fan
Race Coolant
ECU
LINK G4
I use a Raceworks surge tank with an external raceworks pump...all AN fittings and lines however I retained the factory fuel lines which sit on top of the fuel tank (I've got a pic on my Instagram and a video explanation of the setup on my Youtube channel - link in Sigblock).
I ended up mounting mine in the opposite corner to the battery. That way it's out of the way in case I want to install a rear strut mount or cut out the wheel well down the track. Works well, and no surge at all.
I put the rally road dual pump kit in my turbo car.
Seems counter intuitive but using their siphon valve made a big difference in when I get fuel starve at an autocross. There's a lot of ways to do it though.
People with na setups seem really happy with a lift pump in the driver side feeding the passenger. It didn't fix my issues but did help.
For me with a turbo car the dual 485 pumps with the rally road siphon was better.
I think if I did it again I would just put one big walbro brushless pump in the factory hanger and use the rally road siphon valve to replace the factory one.
^agree with rally road dual pump.
