I need help in finding the location for the sensor. If anyone has a picture, that would even help more. Just to be clear, it is for a 1997 850Ci.
Left Front Brake Duct. Take off your left front wheel and look into the square hole, you should see the tip of it. If you don't it is likely hanging on the wire somewhere in there. Pull you fender liner and you will see it.
