Hello!
Bought a e34 540 -93 a while ago.
Not driven since 2015.
Bought it with broken bowden cable and stuck in D
Bought a bowden cable to replace, i noticed the lever It’s hooked to is stuck.
Replaced the cable and couldnt get it to neutral etc.
Also noticed egen i bought it i couldnt get the key out because it was in Drive. After Change of bowden cable i can Take the key out in D
Any ideas?
Jack car up. Disconnect cable from transmission. Can you change gears directly at the transmission now? If so, look around the gear shifter, is there debris or something jamming the cable?
And after that, You may need to pull the shifter assembly out to get a better look/clean the lever and cable mechanisms. Just to clarify, will it move info any of the other forward hear? I.e. 432or1?
Sent from my SM-N950U using Tapatalk
probably broken selector valve
https://www.bimmerforums.com/forum/s...selector+valve
Nope.. the gear is stuck. I can Wiggle it but not change gear
I think shogun probably has your answer
of course you can wiggle it, when it is broken, but it does not change any gear, you only know when you have the part complete in your hand, remove the ATF pan and check it.
same here, all gears stuck in reverse and guess what he found... https://www.bimmerforums.com/forum/s...al+shift+valve
