After taking my 91 850i to two shops still no fix for my AC...I’ve been looking for information on how to modify the lock sensor to make new compressors work with the car but all the threads are old and the images/links no longer work. Does anyone have the information on how to modify the sensor? I also read if you buy the newer sensor it will work with new compressors is this the correct part number? 61358360039 I searched for one and it’s not available anywhere. The summer was almost unbearable driving in my 8er but now the weather is cooling down and I can actually drive with my windows up lol.
OK, this is what you have to do:
Behind the speaker in the LH (Driver's) footwell, is the compressor Lock Sensor.
Remove hood release handle
Remove left speaker kick panel / plastic cover
Remove the speaker pod
There is a plastic box on the inside lower wall of the body cavity, held on by 2(?) nuts on sheet metal. Nuts are outside, towards where your feet would be. Remove those
Now you can reach down and fish the entire thing up and out of the hole.
Great, so now you have this weird box with too many wires in your hand, what to do?
You need to jumper 2 wires.
The wires you need are these:
pin #3 - Black/Red/Yellow
pin #5 - Black/Gray (there are TWO of them that go to the same pin, use either one)
Do NOT cut them out of the original circuit, but strip a bit of insulation off and jumper them together 3-5" before the connector (X77) to the box, tape up the splice & reinstall everything.
Now you can use a new R134 Denso/whatever single wire compressor.
'91 850i 6sp (mint) (sold)
I will post the wiring Diagram Tonight
I did not do it as described above and my AC will only work on coolish days. I am going to go back in and look at this again.
thank you so much!!!! Finally have cold AC blowing I want to cry I love you brother ��
BMW TSB B64 11 92 (3569) E31 850, E32 750 AC compressor shut down
Situation: AC compressor shuts down during heavy rain, or when driving thru deep standing water. The customer complaint is loss of cooling. The condition disappears when engine is stopped and restarted.
Cause: The AC compressor clutch is disengaged by the slip monitoring function of the AC lock sensor control module. This module continiously monitors the engine speed and compares this to the AC compressor speed. The magnetic clutch of the compressor is automatically disengaged by the lock sensor module if the amount of slip exceeds 30%. The intent of this system is to prevent broken v-belt or reduced engine cooling if the AC compressor locks up. If the vehicle is driven in heavy rain or if standing water is spashed up into the engine compartment belt area, the v-belt and pulley may get wet enough to cause slippage in excess of 30%. The lock sensor control module perceives this as possible AC compressor lock up and opens the clutch circuit to prevent damage. The control module will remain in this state with the compressor clutch deactivated until the ignition is turned off and back on, clearing the condition.
Note: in addition to slip monitoring, an engine coolant temperature check has been incorporated into the lock sensor module on E32 vehicles produced since 09/1989, and E31 vehicles since the start of production. If engine coolant temperature rises above 240 degrees F., the AC compressor clutch is pulsed off at regular intervals to reduce engine load. If the coolant temperature rises above 250 degrees F., the clutch is switched off completely. As of 09/1992 production the slip monitoring fuction of the AC lock sensor module will be dropped on both E31 and E32 models.
Solution: If a customer complaint of AC cooling loss is received, the following items should be checked before proceeding with this repair:
-AC compressor belt tension adjusted to specification
-No oil leaks have contaminated the AC compressor belt, causing slip
-AC system pressure is within specificaion, not overloading compressor and belt.
If the above checks do not isolate the source of the slippage, proceed with the following repair. The remedy for this siwation varies with the model and production date of the vehicle. Refer to the appropriate ETM for diagrams showing connector, pin and control module locations.
750iL vehicles from the start of production thru 08/1989
Remove the lock sensor control module from the from the left hand side of the drivers footwell. The unit has 2 connctors, 4-pin and 5-pin and is located in the recesss of behind the kick panel.
Unplug the connectors X77 and X80 from the lock sensor control module body.
Remove pin 1 of connector X77 and pin 3 of connector X80 using a terminals removing tool.
Cut off the terminals and connect the loose wires with an insulated crimp connector. Shrink tubing may also be necessary to prvide proper insulation.
Tape or tie-wrap the loose wires with the other harness wires.
Plug the connectors back into the control module, reinstall the control module and reinstall the kick panel trim.
E32 750iL produced from 09/1989 thru 08/1991:
Remove the lock sensor control module from the left hand side of the drivers footwell, the unit also has 2 connectors, 4-pin and 5-pin.
Replace the lock sensor control module with p/n 61352233107 . This replacement module does not contain the slip monitoring function.
Reconnect the electrical connectors and install control module and kick panel trim.
E31 from start of production thru 08/1992:
E32 750iL vehicles produced from 09/1991 thru 08/1992:
Remove lock sensor control module from left side of driver's footwell. The unit has 1 connector with 10 pins and is loacted in the recess behind the kick panel.
Replace the lock sensor control module with p/n 61358360039 , this replacement module does not contain the slip monitoring function.
Reconnect and install....
Parts information:
lock sensor module 61358360039 10-pin type E31 from start thru 08/1992, E32 from 09/1991 thru 08/1992.
lock sensor module 61352233107 , 9-pin type, E32 from 09/1989 thru 08/1991
my collection of info for M70 lock sensor, lock sensor delete, started in 2010, also added above comments https://www.bimmerforums.com/forum/s...or-delete-info
I was looking at the coloring for the wiring diagram and it says GR Means grey and GN stands for green. Are the wires going into pin 5 black green or black grey? I am going to do this soon I was just trying to confirm the right wires before I got everything apart.
The full diagram is here - and there are a few different versions over the model years: https://www.meeknet.co.uk/e31/e31_91.pdf#page=311
Wire colours are shown here: https://www.meeknet.co.uk/e31/e31_95.pdf#page=20
My BMW Repair YouTube Channel
Got my module out and the two wires at pin 5 are black and grey like the wiring diagram suggest. Pin 3 is black red and yellow. I think cartoonz made a small error. Just trying to be careful because I dont wanna splice wires incorrectly.
I wanted to post a pic of the connector but I can’t figure out how at the moment.
Probably no error - there were a few variants over the years!
wire colors fixed... in my haste, I mis-labled the black/gray as black/green.
Do it exactly as written (now) and it works perfectly.
Got the AC working today. Ice cold. Thanks for all the help.
Is this still required (AC lock sensor trick) for a 1991 BMW 850i? Are there any replacement compressors where this is NOT required?
Thanks,
Tom
The best replacement compressors are Denso - which do not have the 3 wires to the connector, and neither do most other replacement compressors.
So yes, this is required if you go from 3 wire to single wire. Remember, the plug is the same, it just does not have the pulse generator in the compressor.
Hi all,
I have finally managed to fix my AC compreessor and refilled it. tested fine, no leaks and holding pressure. (all this was done with a direct power from the battery to the compressor feed wire).
But no normal power at the compressor plug when the AC button is pressed on. So I believe either the sensor at the compressor or the Lock Control module are the culprit. I need to bypass wire 3 and 5 on the module as per Cartoonz instructions above.
Question:
Where is the A26 module located on a Right Hand Drive car?
thank you
Hi all.
OK, found it, so it is located behind the left front speaker on the right hand car.
But on my car, Pin 3 Black/red/Yellow is correct, but pin 5 is a blue wire. the Black/Grey (two wires) is on pin 1. Bridging both pin 3 and 5 or pin 3 with pin 1, still no power to the AC compressor.
What to check next?
Note that i am using the original Compressor with the 3 wires plug. direct 12v power on compressor and it works well.
Please help.
thank you
HI,
So I bridged pin 1 (Black/Grey (two wires) with pin 3 (Black/Red/yellow wire) and found that I had two misplaced relays on the fuse box, relay K19 and K33. swapped these around and the AC compressor works, great, but...
the AC switches on as soon as I turn the air vent on, without depressing the AC button!! The AC button lights on but makes no difference, what am I missing?
Any hints?, please...
For the 850i, the normal behaviour is:
- the AC is on at start up for 15min (not always, depending on the externat temperature)
- after those 15min, it will switch off if the button (and the light) is OFF
You are misreading the pin placement on the plug... Blue wire is Pin #1
Do NOT include that one!
Jumper the black/red/yellow with the black/grey and that's it.
As for your relay swapping... it sounds like whatever you plugged into K19 is either a "normally closed" (nc) relay or some other oddity.
Hi Ben325,
I didnt know that, need to go read the manual again... either way, hope that this is the case and there is actually no issue. thank you
Hi CartoonNZ,
thinking about it, you must be right... need to get some reading glasses.. the numbering letters are so small that I must have mistaken the one with the 5. What a relief...
Regarding the relays, yes, when I did some work over the relay\fuse box a year or so, I must have mixed them up, go them right now.
Hope this is actually normal, that the AC is on at start up for 15min and not a new problem I need to deal with. Will test it by running it longer this weekend.
thank you very much to everyone
See the full description attached
Nice info ben325, thank you.
I did try it on Saturday, left it idling for about 20min but the AC compressor did not switch off, both the AC button and lights off. Didnt have more time as I had family matters to atted to, but since it works and all seems normal, I will leave it as is. I will consider it solved.
New problem on sunday, the EML is not turning on for a few seconds like it should,,,, so new problem to deal with, I will check the cluster bulbs next weekend.
thank you everyone
