Hi, I am new to the group and I would like to know as much information and help as possible before making any changes. My engine runs overall fine but I have the following symptoms:
- When I start it cold, the tachometer oscillates 1min -2 until the whole engine is lubricated (I guess)
- the sound of air whistling(more of a rubber hose air blow) as if it were losing air somewhere in the intake area, although it appears to be the sound of a hose
- a specific flicker that I can't locate at idle in principle ( flicker/small rattle/can't really pin-point the sound in english, i am not native)
- low power up to 2500-3000 speeds in principle up to 100km / h, after take off and goes really well. (I associated it with delay, it takes something until it gains momentum)
- the engine does not die, it does not suture, it does not skate
What I changed / did:
- oil, all filters, changed the PCV valve were both hoses broken
- when I remove the lid with the engine running, it stutters but does not die
- the vanos in the intake does not make noise, I put my ear on it to listen
- It doesn't sound like a piston issue or noise
- I have only one error in the lamda probes but I deleted the error and it did not appear
- the throttle valve is clean
- I disconnected and connected the DISA damper but there was no difference in sound, it doesn't seem to have any problem
Sorry if I didn't express myself well, I'm still learning and I hope I posted according to the rules. Here is a 70Mb video with all the symptoms:
Thank you for reading, please let me know on your opinions ..
https://share.icloud...WlTYsXpfK9bUKrA
What are you using to read the codes in the engine computer (DME in BMWspeak)? It sounds like you have a vacuum leak. The tachometer oscillates when the engine is idling because of vacuum leaks.
I am not an expert. But sounds good, looks good...thought I might have heard something when you were at the drivers door recording? Guess I would have to be there in person.
Any jobs last done with or around the intake? And you are getting no codes...no?
Cheers!
Sent from my SM-J727T using Tapatalk
i dont really know, the guy that checked has a dedicated software from an ancient laptop and had windows XP on it . However i should re-check all the errors soon, it does oscilate when on idle for like 2 minutes after that it calms down even tho it son idle , so it sounds to me like its a matter of oiling or warming up. I cant identify where it could leak air
Didnt really do anything to be honest , i am planning a few things but i dont wanna go spend money before i can narrow down the list of things that ca be considered an issue. I will soon change DISA device, Vanos intake rubber rings and check AGAIN all the ruber hoses and check for cracks or anything like that. Its pretty difficult to pin-point where i'm leaking air. I will go and check the errors again maybe it can help.
You say... -the sound of air whistling(more of a rubber hose air blow) as if it were losing air somewhere in the intake area, although it appears to be the sound of a hose
Do you have anything else to go on other than sound...once it warms it's fine you say.
Have you spray cleaned the idel control valve, MAF sensor?
Here's one I kept in my library...
https://youtu.be/ue3N5Pg9yJw
So, i had a look around today at the air filter boot and hoses to see if there is anything broken or cracked. Everything is okay, i have took down the DISA and it works perfectly, looks good , no issues in functionality there . I couldnt remove the IDLE control valve but i shall do it in the following days and come back with more feedback ! Also i will put a tester on it. I will check the exhaust for rattle noise, it seems i have a small rattle reving, underneath the car. So i suspect there is something in the exhaust, like some components from the catalyst.
