I know a read somewhere that a member figured out how to connect INPA to the left and right DME's. I searched with the forum and google but I can't find it! I bet it is buried in a different thread. My car is fine as of now but when the day comes and it will with 12 cylinders to keep happy I will need INPA. I hope that member is still here? Something about putting the correct files in a certain folder.
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
I think it is reply #29 in this tread. But I would listen to the Edwin comments. He's not on much anymore, but of the OG e38 guys, he knows his stuff.
https://www.bimmerforums.com/forum/s...-M73-V12/page2
I had to figure this out to diagnose a melted EKAT module among other things on a MY 2000 750il (production 12/99), so hopefully this will help someone else.
Under your INPA\CFGDAT directory, open up E38.ENG in a text editor and make sure you have these lines uncommented (remove the leading semicolon character) or add them manually under the ROOT_MOTOR section:
You'll need the corresponding files (e.g. DME521R2) in INPA for this to work. They should be present in v39 daten and newer ones as well.Code:ENTRY=DME521R,DME 5.21 for M73 right MJ 98, ENTRY=DME521L,DME 5.21 for M73 left MJ 98, ENTRY=DME521R2,DME 5.21 for M73 right MJ 99, ENTRY=DME521L2,DME 5.21 for M73 left MJ 99,
I found this worked successfully on a laptop with a true serial port using an ADS cable, but only while the DMEs were installed in the car. It did not work with a USB to serial EDIABAS adapter in either OBD or ADS mode, nor did it work with the ADS cable on a bench wiring setup. Without troubleshooting further, my hunch is that the IPO script file interrogates another module in the car that's accessible through the ADS port. WinKFP works perfectly fine with an EDIABAS cable for flashing either DME (with a solid 14V power supply), so I know the DMEs are accessible.
nice, I hope never to need this, but I'll subscribe and save....
Just to follow up I changed the lines to uncommented and now I can get into both DME's. It's in German but that can be translated. Another thumbs to the forum!
95 M3 LS swapped
07 M5 Manual
