Results 1 to 5 of 5
Thread: 2001 750il INPA connection to DME left and right
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    I know a read somewhere that a member figured out how to connect INPA to the left and right DME's. I searched with the forum and google but I can't find it! I bet it is buried in a different thread. My car is fine as of now but when the day comes and it will with 12 cylinders to keep happy I will need INPA. I hope that member is still here? Something about putting the correct files in a certain folder.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    I think it is reply #29 in this tread. But I would listen to the Edwin comments. He's not on much anymore, but of the OG e38 guys, he knows his stuff.
    https://www.bimmerforums.com/forum/s...-M73-V12/page2
    Sunnyvale, CA
    E46 M/332i x 2; F87 M2C
    I had to figure this out to diagnose a melted EKAT module among other things on a MY 2000 750il (production 12/99), so hopefully this will help someone else.
    Under your INPA\CFGDAT directory, open up E38.ENG in a text editor and make sure you have these lines uncommented (remove the leading semicolon character) or add them manually under the ROOT_MOTOR section:
    Code:
    ENTRY=DME521R,DME 5.21 for M73 right MJ 98,
    ENTRY=DME521L,DME 5.21 for M73 left MJ 98,
    ENTRY=DME521R2,DME 5.21 for M73 right MJ 99,
    ENTRY=DME521L2,DME 5.21 for M73 left MJ 99,
    You'll need the corresponding files (e.g. DME521R2) in INPA for this to work. They should be present in v39 daten and newer ones as well.
    I found this worked successfully on a laptop with a true serial port using an ADS cable, but only while the DMEs were installed in the car. It did not work with a USB to serial EDIABAS adapter in either OBD or ADS mode, nor did it work with the ADS cable on a bench wiring setup. Without troubleshooting further, my hunch is that the IPO script file interrogates another module in the car that's accessible through the ADS port. WinKFP works perfectly fine with an EDIABAS cable for flashing either DME (with a solid 14V power supply), so I know the DMEs are accessible.
    -Kalim
    (klx photo studio)
    M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit
    KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings
    Nov 2016
    NY
    nice, I hope never to need this, but I'll subscribe and save....
    Nov 2016
    Hansville, wa
    Just to follow up I changed the lines to uncommented and now I can get into both DME's. It's in German but that can be translated. Another thumbs to the forum!
    95 M3 LS swapped
    07 M5 Manual
  1. E36 318is Problems with INPA connecting to DME
    By cristimm in forum Diagnostic Software
    Last Post: 05-27-2016, 05:58 AM
  2. 318is Problems with INPA connecting to DME
    By cristimm in forum 1991 - 1999 (E36)
    Last Post: 06-07-2015, 06:57 AM
  3. Replies: 5
    Last Post: 02-23-2013, 04:21 PM
  4. Looking for 2001 750iL Protection
    By lucal in forum 1995 - 2001 (E38)
    Last Post: 04-21-2004, 02:56 PM
  5. 2001 750il 500 over invoice
    By SilverShifter in forum BMW Parts For Sale
    Last Post: 05-20-2001, 03:46 AM
