Results 1 to 9 of 9
Thread: E46 m3 master cylinder upgrade for BBK
    Aug 2020
    bc
    m3
    I purchased a 2006 m3 with the Alcon 6 piston front and 4 piston rear bbk. The brake pedal feel was terrible with a low sinking pedal and a lack of modulation as just breathing on the pedal caused way too much deceleration. I upgraded to a Porsche 997 carrera booster and 997 gt3 master, part # trw : pmn166. I’m pretty sure all 997’s use the same master . You will need to fabricate a small adapter from the pedal to the threaded booster shaft. And shorten the hollow threaded part on the booster to use the long m3 bolts . Now the pedal is as firm as a 997 gt3 with no travel .
    How do I post pics?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by racingdriver View Post
    How do I post pics?
    There is a post count threshold, for now store on a third party friendly hosting site and provide a link.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Sounds like air in the system coupled with a low torque pad compound like PFC08.
    Aug 2020
    bc
    m3
    No air and street/track pads. The fluid displacement from a 2 piston front to a 6 piston front , 1 piston rear to 4 piston rear Calipers is substantial. The stock master is designed for stock Calipers and does not have the volume to fill all those pistons without pushing the brake pedal down. That is why production cars with these huge Calipers have bigger masters to preserve a firm pedal.
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    That's interesting, as I have a Z3 3.0i brake master cylinder in my car on Porsche Brembo 993TT big red front calipers and 998 rear calipers without any issue.
    Maybe its your pad compound, I've never had good luck with PFC08s. Worst pads I've ever put on my evo and my E92M.
    Oct 2003
    Colorado Springs
    E30 M3,E28 M5,E39 M5 etc
    Piston count has nothing to do with pedal feel. overall piston displacement is what can change how the pedal feels. How much surface area do your alcon calipers have compared to stock? E46 M3 has single piston calipers at all 4 corners by the way. I think you already know that but your 2 -> 6 front 1 -> 4 rear statement doesn't support my assumption.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I know a 6 piston Stoptech ST60 for my E90M3 has slightly less total piston area than the factory 1 piston sliders.
    Oct 2021
    Italy
    M3 + CSL
    you’re right
    How do I post pics?
    You’re right, same issue on my 2001 M3 E46 with Apracing 6+4 all around.
    The piston area increase too much for the stock pump, which is even narrower on diameter than the 2002+ M3.
    It seems I could solve with a Z8 brake pump, whick is 27 mm at the front.
    I couldn’t swap the 997 pump because I need a 3 port pump to connect the precharge pump which MK60 brake system on 2002+ does not have.
    Dec 2016
    Los Angeles, California
    2002 E46 BMW 325i
    Quote Originally Posted by Pepia View Post
    Did you come up with any solution? The downside with the Porsche master cylinder is it doesn't have ports for the brake pressure sensors
  1. E46 FS: E46 M3 Master Cylinder. NEW OEM
    By apexbmw in forum Brake Kits, Rotors & Pads
    Last Post: 02-22-2012, 12:43 PM
  2. e36 m3 master cylinder upgrade
    By s14realm3 in forum 1991 - 1999 (E36)
    Last Post: 09-01-2011, 12:23 PM
  3. M3 master cylinder upgrade- any other parts needed
    Last Post: 06-30-2011, 08:09 PM
  4. FS 2004 E46 M3 Master Cylinder and Booster
    By CP Louie in forum Brake Kits, Rotors & Pads
    Last Post: 06-02-2009, 04:22 PM
  5. WTB e46 330 brake components + e36 M3 Master Cylinder
    By Ahheck01 in forum BMW Parts Wanted
    Last Post: 02-08-2006, 11:50 AM
