Results 1 to 9 of 9
Thread: How to stop Horn alarm?
    Mar 2019
    Vancouver, CA
    BMW 550i
    Exclamation How to stop Horn alarm?
    I have 525i 91. I am not sure what happened. It was working fine and then I put different battery. I put it first time wrong direction - to + / + to -. Idk if this did smth but when I put it right way by horn alarm just going crazy. It seems the same issue like I found here (911 Horn wont stop blaring). And that exactly whats happening when I plug the battery in youtube.com/watch?v=hMeYwlyggX8. Im not sure if I just need to cut this alarm?
    https://www.youtube.com/watch?v=hMeYwlyggX8
    Apr 2019
    canby, OR
    1990 bmw 535i
    Its a security system, connect the battery then stuck your key in the drivers door and turn it, i cant remember if you need to lock it or unlock it but just stick it in the lock cylinder and turn it bolth ways and it should stop
    Sent from my LG-US998 using Tapatalk
    Mar 2019
    Vancouver, CA
    BMW 550i
    Quote Originally Posted by bimmer@15 View Post
    Have tried. Didn't help
    Mar 2019
    Vancouver, CA
    BMW 550i
    So I unplugged on-board computer and car stopped alarming. It starts and everything. When I plug it in nothing shows up and it just starting alarming again
    Apr 2019
    canby, OR
    1990 bmw 535i
    I know that some obc can have a pin used to disable the car, maybe its that
    May 2017
    Perth, Western Australia
    some
    Yep, the OBC can have a security code to set of the alrm/horn and disable the car. Best guess is that's been fried if the problem started after connecting a battery wrong. Isn't the coding plug for the whole system supposed to be plugged into the back of the OBC or somewhere in the dash wiring? Maybe that system is damaged also?
    OBC manual: http://www.mediafire.com/file/cx0z1z..._info.pdf/file
    It says there if you disconnect the battery and try again there should be a count down timer of 15min then after that it's reset.
    After that maybe it's permanently disabled? It wasn't clear about that, it just said for emergency start if you don't know the code: disconnect battery 1min, then reconnect and put up with the horn for 15min and then you can drive! LOL
    If there's no ODC display then consider it toast I guess.
    E: Also check shoguns link: http://bmwe32.masscom.net/johan/obc_...c_secrets.html
    and the owners manual about the OBC alarm http://www.mediafire.com/file/eifibe...anual.pdf/file
    Mar 2019
    Vancouver, CA
    BMW 550i
    Thank you guys for your help. Yeap I have a feeling that its fried. I have 2 other E34 that I can try to plug in their on-board computers. Will they fit or you gotta have exactly same year production one?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    If they are identical, they will fit, there were OBC III (earlier version) and OBC IV.
    Or just disconnect the alarm horn, that is in a different location than the normal horn. On my E32 the normal horn is behind the kidney grill, the alarm horn is on right side next to the windshield wiper mechanism, difficult to access.
    Antitheft Horn H1 is located below right hand fresh air cowl.
    Sep 2017
    Vienna, VA
    1995 525i E34 6-speed
    I know I am late to the game, but I have seen this failure before. There is a relay on the later cars that is part of the loom for the remote key fob module that is under the back left seat. This relay dangles into the battery well under the back right seat. In my case, I was working with a car that had sunroof problems and the battery well would fill with water. This shorted and then corroded the internals of the relay, to the point that it would stay shorted when the water was drained. Unplugging this single relay solved the problem.
  1. Alarm siren same as horn? ALARM PROBLEM
    By Lunadan in forum 1996 - 2003 (E39)
    Last Post: 06-22-2015, 02:19 AM
  2. Replies: 0
    Last Post: 05-08-2012, 11:16 PM
  3. OEM Horn/Alarm
    By T325i in forum 1991 - 1999 (E36)
    Last Post: 07-19-2008, 12:28 PM
  4. Obnoxious Horn/Alarm
    By BLACKPHANTOM9 in forum 1991 - 1999 (E36)
    Last Post: 01-15-2008, 04:02 PM
  5. Replies: 20
    Last Post: 05-11-2006, 02:01 AM
