I replaced the ps reservoir and the hoses that attach to it and now when I turn the wheel all the way left/right fluid comes squirting out underneath the pump. Will a repair kit fix my pump or will I have to purchase another?
The kit: https://www.fcpeuro.com/products/bmw...135880#reviews
Need more info on what is believed to be happening?
You already rebuilt the pump or are you asking if rebuilding the pump will correct this problem?
Did you have this problem before replacing the reservoir and hoses?
Sounds the the banjo bolts are not torqued properly. Over torquing can distort the hose end fittings. Were new crush washers used on the banjo bolts?
Sounds like they are not sealing right. Verify the seals are not pinched and make sure all the air is out of the system. There are a few videos on how to get all the air out on YouTube.
And to answer your original question, that kit will reseal a ZF pump. If you have the uncommon Valeo pump, it will not.
"Howdy, Folks!"
yeah I bought/installed new washers and banjo bolts. I really hope I didnt over torque the banjos. Will I need a new hose if I did?
I have not rebuilt the pump. I believe its the original. When I first bought the car the steering pump would squeal whenever I turned the wheel all the way left/right. It was already leaking when I bought it.
Thank you all for the answers I truly appreciate the help. Im still learning!
