Results 1 to 13 of 13
Thread: 740 overheating, help!
    Mar 2010
    London, UK
    BMW 840
    I recently changed the coolant tank as there was a water leak. Now after the car being on for around 45mins-1 hour the temperature starts rising.
    Any ideas?
    BMW 840, INDIVIDUAL DAYTONA PURPLE , 20 INCH ALLOYS, MAGNAFLOW QUAD EXHAUST SYSTEM , CSI BODYKIT, CARBON FIBRE BADGES, BILSTEIN SHOCKS, ELBACH LOWERING SPRINGS, ALPINE HEADUNIT WITH 12 INCH SUBS.
    IL
    2000 740i sport
    Quote Originally Posted by Naz840 View Post
    Any ideas?
    Did you bleed the cooling system properly?
    Mar 2010
    London, UK
    BMW 840
    Quote Originally Posted by purplecty View Post
    Yes, the system was bled properly.
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    Bleed it again. Nothing else changed, except you opened the system introducing air. More than likely that is the problem.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    .....and:
    My BMW Repair YouTube Channel
    Mar 2010
    London, UK
    BMW 840
    .....and:
    I’ve noticed that when the car is at full temperature the fan is only going around at the same speed even when you increase the revs.
    I think the fan might need changing? Doesn’t feel as strong as my fan on my 840.
    IL
    2000 740i sport
    Fan as in fan clutch? If so time to replace it...
    https://www.fcpeuro.com/products/bmw...m-11527502804b
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    If the temp is going up when moving, then it is likely not the mechanical fan or fan clutch. Are you in the UK? If so, the ambient temp is low enough to not be a factor. If it creeps up in traffic, stop lights, then look at it. Also, if this is new behavior since you swapped the overflow tank, then it’s a bleeding issue. I know, you don’t want to hear that. Did you put the heat on full hot, and the fan on high?
    IL
    2000 740i sport
    I'm with CPHES! There is probably still air bubbles trapped in the system somewhere that need to be bled out. Raising the front end up helps as well. These can sometimes be tricky to bleed properly...
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    My e38 was the most difficult BMW I've had to bleed to date. Took multiple times, even using Tim's method.
    Oct 2013
    California
    2003 Convertible Hardtop
    Any ideas?
    What else did you change besides the coolant tank? If nothing else, I know it is hard to believe but you have a pocket of air in the system. The only other item that would cause this is blockage of some type and we know that is not the problem. When there is air in the system, some of the radiator fluid is no longer moving through your system. Put your car on an incline and follow exactly the video above.
    Nov 2016
    NY
    Also, how much coolant came out when you changed it, and what bleeding procedure did you use the first time? Are you watching the temp gauge, or are you watching the temp from the secret menu on the cluster?
    Mar 2010
    London, UK
    BMW 840
    **Update** replaced the viscous fan and it has solved the overheating issue!
  1. 328is overheating!!!! help
    By ehlpitel in forum 1991 - 1999 (E36)
    Last Post: 12-21-2003, 06:55 PM
  2. Overheating, HELP!
    By KidCorrado in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-08-2003, 03:43 PM
  3. Overheating HELP!!
    By AndyZ3 in forum 1991 - 1999 (E36)
    Last Post: 05-30-2003, 02:22 PM
  4. Car overheating...HELP please!
    By C///M in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-14-2002, 06:52 PM
  5. Overheating Help!
    By akbart in forum 1991 - 1999 (E36)
    Last Post: 06-04-2002, 12:27 PM
