Results 1 to 3 of 3
Thread: Why Did This Happen? Clutch Master Failure
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    https://www.youtube.com/watch?v=-PNINyloM4s
    This was replaced 5 months ago. Febi brand. The system never bled properly despite proper method. Pedal usually not returning to full rest. Pedal had been repaired after a tear (seen below) but seemed to be in original parameters.
    I was able to get the ball end of the eyelet shaft back into the deformed opening but wanted to understand why it happened.
    I will be getting under warranty a new part tomorrow but think I should harvest my other intact 540 clutch pedal in case this repair left this pedal slightly off allowing for excess travel and possibly forcing the ball end through the retainer.
    Attachment 679641
    failed part;
    Attachment 679642
    I also wanted to ask if the correct placement for the clutch pedal spring is to locate the two tabs at the bottom into the groove in the small metal plate on the firewall behind the pedal. This was where I had it positioned.Attachment 679643
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Mar 2005
    NH
    Quote Originally Posted by moroza View Post
    I'm not sure what I'm looking in the second picture. The third picture is incorrect - the two tabs on the spring should be located in the large middle groove on the pedal bracket.
    Sorry I realize that was worded confusingly.. I meant to say I had it positioned as I described my understanding that the groove was where the tabs go . It was there I just added the image for general reference and see its not located correctly there but I was removing or replacing it when i took that... and moreover I only bumped this thread because I wanted to try adding the image of the wheels I have on my junker to the classified thread but the manage attachments section was missing from the posting form.. I could only copy the image from the above post to link in the classified thread.
  1. Clutch master failure with Mason pedal
    By saber63 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-21-2016, 10:03 PM
  2. Replies: 10
    Last Post: 08-17-2015, 12:43 AM
  3. 87 E30 Clutch Master Cylinder, any idea why??
    By trinisonic in forum 1983 - 1991 (E30)
    Last Post: 10-08-2012, 11:42 PM
  4. Clutch master cylinder failure
    By cliffhopper in forum 1992 - 1999 M3 (E36)
    Last Post: 12-02-2010, 03:47 AM
  5. Replies: 1
    Last Post: 01-26-2005, 05:03 PM
