Results 1 to 5 of 5
Thread: Pads and Rotors
    Mar 2020
    MD
    2008 M3 Coupe
    Pads and Rotors
    I am in need for a new set (front & back) pads and rotors. I do not track the car...spirited driver. Of course would like less brake dust, would like to maintain the factory feel. Any advice would be appreciated. First time replacing brakes on this car so all the guidance and things that I must also replace besides the pads and rotors....
    Thanks,
    Mar 2020
    MD
    2008 M3 Coupe
    bump....Anyone with input????
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Ceramic pads dust less. Akebono is a popular choice, but they won’t have quite as much initial bite as stock. They should stop your car in about the same distance. Buy new break pad wear sensors as well. If you have not bled the brakes in a couple of years, do that as well. Best E9xM3 forum is in M3 Post dot com.
    Houston or thereabout
    '13 M3 Coupe
    Why buy new sensors if there is nothing wrong with the old ones? I can see buying new sensors if you actually triggered them or they are damaged in some way; otherwise this is just throwing away some money.
    2013 BMW M3 Coupe : Interlagos Blue : Silver Norvillo : 6MT : Competition Package
    pics of M3
    Jun 2005
    New England
    If you have success reusing sensors that have been stuck in the pads for 40,000 miles, then sure, try reusing them. After 5 years of driving in rain and snow, I find they often break upon removal or fit the new pads very loosely and fall out. New ones don’t cost much. You can also skip the sensors and just cut the terminal off and connect the wires together.
  1. What tools will to change pads and rotors?
    By T///MW in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2004, 05:06 PM
  2. Question on pads and rotors
    By Harry in forum 1991 - 1999 (E36)
    Last Post: 03-17-2002, 10:28 PM
  3. How much $$$ for pads and rotors??
    By Andrew 97M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2001, 10:04 AM
  4. Suggestions on brake pads & front rotors?
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 04-20-2001, 09:05 AM
  5. Brake pads and rotors
    By Techno4doorM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2001, 08:49 PM
