Results 1 to 4 of 4
Thread: Wiring a driver's seat without memory functions?
    Sep 2015
    San Diego, California
    94 740i, 03 525iT, 86 VW
    I'm installing some E32 front seats in my motor home and I just realized that the wiring on the driver's side is not nearly as straightforward as the passenger side due to the memory functions.
    On the passenger side all I had to do was connect 12v to the red/yellow wire and ground the brown wire.
    On the driver's side I'm totally lost. I suppose I need to trace each set of wires going to each motor, but maybe someone here has tips for me on which wires do what and how to proceed.
    By the way, we are three Bimmer family, see this pic:
    I have wrenched on vehicles with:
    1 cylinder
    2 cylinders
    3 cylinders
    4 cylinders
    5 cylinders
    6 cylinders
    7 spoke wheels
    8 cylinders
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Maybe.....if you find the plus and minus pins going into the SMM control unit, you might be able to move the seat without the memory function, SMM info here http://www.e38.org/e32/BMW_pdfs/
    for the wires you have to check the ETM of the built year the seat came off. https://shark.armchair.mb.ca/~dave/BMW/e32/
    Sep 2015
    Quote Originally Posted by shogun View Post
    Thanks for that info shogun, but I have already removed the original harness and I will replace it with the harness and switch from a passenger seat from the local breakers. I will post any details in case anyone else wants to put E32 seats in a motor home, go kart, etc... ;-)
    1 cylinder
    2 cylinders
    3 cylinders
    4 cylinders
    5 cylinders
    6 cylinders
    7 spoke wheels
    8 cylinders
    Jan 2005
    Japan
    Just found info an on the German forum , but there they refer to the SMM module
    X649: (the one with 5 contacts)
    Pin 1 - Terminal 15
    Pin 3 - Terminal R
    Pin 6 - ground
  1. HOW-TO swap a memory seat without losing memory functions
    By SpeedsterBek in forum 1988 - 1996 (E34)
    Last Post: 06-11-2022, 04:35 PM
  2. Driver's Seat Without Memory- How to diagnose problem?
    By crb635 in forum 1976 - 1989 (E24)
    Last Post: 05-14-2013, 11:33 AM
  3. WTB Non-memory Driver's Seat Wiring Harness
    By theos in forum Car Audio & Electronics
    Last Post: 04-01-2012, 10:32 AM
  4. Seats with Memory Function
    By mbonder in forum 1988 - 1996 (E34)
    Last Post: 12-10-2011, 06:08 PM
  5. None of my driver's seat power adjustment functions work
    By bcolins in forum 1996 - 2003 (E39)
    Last Post: 05-12-2008, 05:23 PM
