Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: front lower control arm, but hub us stuck to shock.
  1. #26
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    That pinch bolt looks too short because you are installing it the wrong way (see pic above).
    Reverse it, the nut goes from the other inside...and it will fit just right, with about an inch to spare for the nut.
  2. #27
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    How will it get longer by changing the direction?
    Dykaar, sure you didn't pick up the wrong bolt?
  3. #28
    Waterloo, ON, Canada, eh
    00 540i-6, 86 951
    I think I musta switched the bushing and pinch bolts. Doh. No harm, no foul. I'm tempted to see if its longer the other way though...
    Regards,
    doug
    Waterloo, Ontario Canada, eh
    16 E400 4Matic Wagon (wife-mobile)
    86 951 (http://pcaucr.org/media/image-galler...all&gallery=22)
    01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
    00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
    94 855 turbo Wagon (sold in 09)
    85 535i-5 (sold in 07)
    76 300D (sold in 92)
    83 944 (sold in 86)
    I apparently only buy cars designated by numbers
  4. #29
    Jul 2010
    Ontario, Canada
    2003 BMW 530i
    Quote Originally Posted by dykaar View Post
    Next question: Rather than have my entire family sit in the car while I torque the bushing bolt, there is a measurement of fender to wheel lip that can be used (as per Bentley). Can someone give me that number for a 17" rim on a 540? Here is a link where they list it for sixes.
    Attached images are from TIS with the front right height data for a 540/m62
    I wouldn't worry too much about loading to "normal position" For my 530 M54, the difference in front ride height "weighted" vs unloaded car with driver only is 9 mm difference, which makes only a tiny difference in the angle of my thrust link wrt the bushing end. I doubt your 540 would be much different.
    Rear ride height is another case though - 26 mm difference weighted vs not
    Regards
    RDL
  5. #30
    May 2018
    Cullowhee North Carolina
    1999 323i/5 2002 540i/6
    I just cranked a jack under the hub until the weight of the car started to come off the jack stands. 20k miles later no issues.
    Sent from my SM-G973U using Tapatalk
  6. #31
    00 540i-6, 86 951
    Next question: Which nut goes on the hub pinch bolt, and which goes on the control arm bushing bolt?
    Regards,
    doug
    83 944 (sold in 86)
  7. #32
    JimLev's Avatar
    Sundance Mesa, NM
    Without crawling under my car to look I say the one on the right is fore the pinch bolt.
  8. #33
    00 540i-6, 86 951
    I agree, but the picture above from Jim Lev looks like the other one...
    Regards,
    doug
    83 944 (sold in 86)
  9. #34
    JimLev's Avatar
    Sundance Mesa, NM
    I just looked at my pic, your correct.
  10. #35
    00 540i-6, 86 951
    And Real OEM agrees: Self locking collar nut on the control arm bushing clamp bolt.
    Regards,
    doug
    83 944 (sold in 86)
  1. How-to on Front Lower Control Arm Bushings???
    By UNVMYM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2009, 08:02 AM
  2. Front lower control arm bushings
    By M3RACER in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2007, 09:06 PM
  3. FS: 96+ M3 front lower control arm bushings
    By LEVOC///MPower in forum BMW Parts For Sale
    Last Post: 04-27-2006, 01:02 PM
  4. Front lower control arms / Bushings
    By Dinanify in forum 1992 - 1999 M3 (E36)
    Last Post: 06-18-2003, 05:58 AM
  5. GC Front Lower Control Arm Bearings
    By siastuning in forum BMW Parts For Sale
    Last Post: 06-12-2003, 02:19 PM
