Can someone tell me how I can cross the numbers on the white tag on the diff to something. I can read the ratio but the other numbers aren't part numbers
that I can cross in Realoem. I trying to do a diff swap and what to be sure of what vehicle it come out of somehow. Any help would be much appreciated
thanks
You probably can't even trust those numbers, the tags are only bolted on so they are easily swapped or removed etc. There is usually a physical difference between the small, medium and large case diffs, generally the back cover is a bit different on them all at a minimum
I do not have what you are looking for but this is were the various ratios come from.
