Hi,
This is a bit of a stange one.
I'm looking to put a BMW F87 M2 Copetition Gearbox into a Nissan Skyline R33.
I'm halfway through the process:-
Adapter Plate on order, HTG controller on order, Haltech Elite 2500 and IC-7 on order
I have the gearbox and I'ce removed the ECU ready for the HTG to be wired in.
I have the BMW paddles and I've tested them and built a circuit so I can get the correct voltage inputs on an anlogue input.
This is usinga potential divider network as per teh HTG paddle shift diagram
BMW Paddle Set Up
Operation Operation R1 +ve Res -ve Res Res Vout
+ve Open/-ve Open None 2200 6100 6500 3146.825397 2.94
+ve Open/-ve Closed Downshift 2200 6100 350 331.0077519 0.65
+ve Closed/-ve Open Upshift 2200 1100 6500 940.7894737 1.50
+ve Closed/-ve Closed Both 2200 1100 350 265.5172414 0.54
I've got the gear selector switch and the Drivelogic button
I also have the parts to make it drive by wire
Throtte peddle and body.
The parts I'm really missing are the connectors.
BMW M2 F87
Throttle Body Connector
Throttle Peddle Connector
Gear Switch Connector
Drivelogic Button Connector
Paddle shift connectors
Can anyone help point me in the right direction to get them or at the very least tell me the looms they are on
Any help apprecaited, searching googlle and ebay is giving me a headache....
Regards
Stu
