Thanks for posting the strut insert install, I've heard it talked about but I finally understand it. It looks like the linked Dinan product photo is not correct then? It appears to show a full yellow strut, but obviously that is not what you have installed.
I found a very succinct Koni install video for anyone else who is behind the curve like me on suspension issues:
https://www.youtube.com/watch?v=PXSnNZt3NiI
I believe the photo on the page is the kit for the standard E36 where you do not need to undertake this level of craziness. So I was a tad surprised to learn that I needed to get OE shocks just for the darn housings (the Bilsteins the car came with were beyond gross and I don't think they would have worked anyway).
Delivery from overseas today, sneak peek.
ok that's pretty cool
Even your workspace is clean......
Very very cool!! I'm jealous I can't use it.
There are currently a few Alpina diff covers to be found (with some intense googling). I ordered from what appeared to be the *least likely to get ripped off* source that I could find, and fortunately, it all worked out!
Thanks It has taken me a LONG time to get this organized, and I think I still have a good ways to go. It certainly is nice when you have no time constraints to deal with and can take things slowly/methodically. I have some more garage renovation planned once I can get this car rolling again (I need it out of the garage to do so). Oh, and a shed would be nice too so that I can stop bumping into all of the family bikes!
More restoration porn, rear calipers.
Looking good! I should do the same with my calipers before I install the SS brake lines.
Just a bit of info on brake caliper piston reassembly since I found a lot of conflicting information out there.
(after using brake fluid to lube / install the rubber ring gasket inside the caliper)
Position the dust boot at the bottom of the caliper piston, and position the piece that needs to seal so that it is hanging below the piston. This allows you to easily insert the piston gasket into the caliper flange which holds it. You should not need to use any tools other than a simple plastic trim tool to ensure the gasket is seated (do not use a screwdriver, pick, or anything that could tear the boot). Once inserted, simply push the caliper piston down, ensuring it is straight so that you do not bind up on the inner rubber ring/gasket. For me, the fronts went in by hand, but the rears needed some gentle help from a c-clamp. Once complete, use air to push the piston partly out to ensure the dust boot is properly secured on the piston. Fin.
Chasing threads is my new favorite hobby
Threadlocker (for solid brake guides, do not use on OE) then torque to spec
All done. Will lube everything upon install.
Ok, I am convinced. I will be rebuilding the entire caliper and doing the paint work. I also have the same brass brake caliper guide set.
I would not recommend red loctite on the brake caliper guides. They have to be removed to put new pads on and to grease the brass bushings.
Grab the Por15 caliper paint kit and a small pack of artist paintbrushes on amazon, it worked well. Also, note my hack of drilling a hole on the bottom of the can and sealing it with a screw - it is a much easier way to use without constantly opening the lid.
The install procedure for the solid caliper guides calls for chasing the threads and then applying threadlocker. I'm using red for its claimed 500-degree heat tolerance before weakening, which is rather optimistic in my experience, but I'm not worried about these things going anywhere.
I just updated my post disclaiming that to not create confusion.
Weird. I guess you will have to remove the caliper bracket from the spindle every time you have to replace pads/grease the pins. Seems like a pain. I've been running the brass guides for over 5 years, no loctite on the pins. Just torque to spec.
Same ^ ...I don't recall the instructions requiring loctite but so maybe it was updated. I check the pins every oil change.
So I am becoming a bit of a DS1 hoarder, and I have one more on the way. I am in the midst of selecting the cleanest candidates for refinishing (or perhaps just all of them). I've spoken with two shops and they have two different approaches. One recommends sandblasting and powder coat+clear (prismatic), and the other wants to acid dip and paint - claiming to follow the process that BMW used at the factory. In the past when I have had wheels done they have been powder and I have had no issues, but I'm wondering if it will play well with the engraved BMW MOTORSPORTS lettering. Does anyone have experience with this one?
You're going to get less definition in the stamping with powdercoat as it fills in the recessed area more. Additionally, powdercoat clear does not last. It doesn't matter what sales spiel the shop tells you, powder clear will crack over time. When that happens is determined by the application quality. There is no proper silver powder either and the final color brightness is extremely dependent on the blasting media used. Dull blast = gray silver. If the shop tries to tell you the powder hides any base color it is applied to and will not show through, you do not want to use them.
Paint is always going to be the most accurate to original. Powder is a good option if you know what to expect and have true professionals doing the work. Both types of refinishing can be fouled by careless work though.
Best of luck.
Go with the acid dip and paint.
It would have cost around $600 for having a wheel repair/refinish shop to refinish a set used DS1s I already had $500 in. I ended up painting them myself. The shop that powered coats probably glass beads not sandblast but uses words sand blast. I glass beaded sections on 3 of my wheels since they had been repaired & painted before and the original material is flipping on there good. I should have at least paid to have them dipped. I thought I had better pictures but this is right after I got tires mounted for the first time.
After a few months of use.
bigger question is which would be more reliable to hold up abuse? Powder coating vs paint (obviously if you go powdercoat, don't do a clear finish)
I had purchased 4 front stamped Style 24s a while back and had 2 refinished by a professional wheel shop. These were painted and the paint was much too thick around the lettering, and I ended up selling these keeping the other 2 with the original finish. It looked ok on its own, but not if you know what it's supposed to look like. Point is make sure whoever is painting it knows what they are doing.
