Hi, when refurbishing the brake system in the rear I found one of the spring coils broken, bottom ring is broke off (about 3") Does anyone know if Z3 rear coils would fit? Seems difficult to source used coils for the z4...
Why would you use used coils..... ????
because it seems all others are aimed to lower the car. Which I don't want..
Replace with OEM then...
I believe Z3 and Z4 has completely different rear suspensions geometry.
Z3 (1)
https://uploads.tapatalk-cdn.com/202...5f529d699a.jpg
Z4 (2)
Could check real oem for both cars to see what part # both use.
