Results 1 to 3 of 3
Thread: 1600 engine replacement
    Jul 2016
    Hendersonville, NC
    1994 325i convertible
    My 1600 has a bad engine. But to save money- interested in swapping g a used engine. Wonder if any m10 will do? Also- want to stay with a carburetor not injection. If I go with a later m10 is there anything complicated about swapping the intakes. Thanks. Bill
    Jun 2018
    MT View, HI
    '80 733i , '76 2002
    Yes is the short answer. The intakes have a couple tricky bolts, but nothing crazy. My concern with an upgrade is the carb. Don't know if the 1600 fueler is up to the task. Maybe think about the weber 32/36 with the two hole manifold.
    Dec 2002
    Scotts Valley, CA
    '64 1800, '72 Touring
    All M10s from the '02 series will fit. With some additional work you can even fit the s14. The blocks are almost identical.
    but, yes, all 1.6l, 1.8L, and 2L will bolt in. I would recommend bringing the carburetor with the motor that you are installing as they were jetted differently. Through '73 it was single barrel Solex, in '74 they switched to a dual-barrel. Most have been replaced with a variation of Weber. 32/36 or 38/38 for down draught and DCOE for side drought.
    Here you can find ways to identify an engine by its block or head (not all will match)
    Steve K.
    BMW 2002 FAQ - most important tool in your 2002 box
  1. S54 engine replacement done! part 1
    By BMWguy206 in forum 2001 - 2006 M3 (E46)
    Last Post: 09-16-2002, 12:07 PM
  2. Day 6 and 7 of S54 engine replacement
    Last Post: 09-11-2002, 01:33 PM
  3. Day 5 of S54 engine replacement
    Last Post: 09-08-2002, 11:17 PM
  4. Day 4 of engine replacement.
    Last Post: 09-06-2002, 04:54 PM
  5. Day 3 of engine replacement
    Last Post: 09-05-2002, 02:10 AM
