I'm starting with the 298/290 set, I have that on the shelf. I am working on a custom set from Cat, the intake cam is about 298 degrees in advertised duration, but 32 degrees from 0.1mm to 1mm of lift. 13.5mm peak.
Fyi, at 36mm base circle you cant get much more than 12.5mm lift without the lobe hitting the cam tray. So 30.5mm is your max overall cam radius before you have to start relieving the tray.
I am also not using the solid lifters with shim caps that go over the valves for my solid lifter conversion. I am using stock 35mm lifters that are converted to solid by using stackable machined shims that you install inside the lifter piston after you removed the spring/check valve guts of the factory lifter, made by my friend Perry.
No machining involved, the shims are made in varying thicknesses so you just stack the right combo to get your desired valve lash clearance.
Sent from my Pixel 3 using Tapatalk
Solid Lifter Conversion
― George Orwell
This is the best NA thread I've seen in years! Wow!... the possibilities!
Yeah, good stuff ... there is lots of good knowledge floating out there for sure!
Haven't heard of any issues with Cat cams ... but we do only have experiences with 2 sets so far!
A friend of mine helped me stop worrying. 11.5:1, .020 off the head & block, stock cams... what are you worrying about? You got a programmable ECU... the tuner will make sure it runs. So yeah, I'm good now.
Reusing the hydro lifter and using stacable shims seems a lot easier method for adjusting valve lash, thanks for sharing.
Keep us posted on the custom cam you are working on. Seems you will reduce the overlap and increase lift, so you will increase dynamic compression?
I have been running ebay long tubes for years in my race car, happy with the performance on my 2.8L engine, 264hp on Mustang dyno (with 1.23 correction to mimic a Dynojet per the shop owner). That said, I plan to buy new headers for the new build....any budget consious suggestions from the group? I am on the loookout for used Kromerkrafts....
― George Orwell
"I’d suggest raceland euro m3 SS reps"
I get lost in the naming convention.
The raceland site has one set of E36 headers,
https://raceland.com/product/bmw-e36...haust-headers/
So, are these considered "euro M3 SS reps"?
By far the best bang for the buck on those headers ... we have the real SS ones as well as the Raceland, and other than some small "because china" issues, they are a perfect copy. They also make great power for a tack engine in higher RPMs.
Get a nice Y collector into a 3" pipe, add in a Magnaflow 4x10 muffler at the end, you're good to go. Do not put the muffler in the middle. It does fit, but it does not last ... too much pressure and heat, so it get blown out and becomes a metal rattling can, lol.
Another edit: The flanges on the headers suck. We cut them off, then use a slip joint on the Y collector, with some header springs from a motorcycle shop ... works perfectly, and takes 2 minutes to remove the exhaust.
Awesome! Thanks.
Currently running BW Y-pipe to 3" custom with resonator and some random magniflow muffler. So, yea, Y collector to a 3" is what I'd do.
Love the idea of slip-joint with the old 2-stroke-collector springs idea!!!
Let's talk about gall plates... you know, the giant washer like disc for aluminum flywheels? Do I need on my ClutchMax lightweight steel flywheel? Or really just for the aluminum ones?
01AFF7C5-7FCA-4C16-8229-85B0C9FA698D by D S, on Flickr
Can’t hurt, however it is typically to prevent damage to the (softer) aluminum FW during installation/application of torque of the attach bolts to prevent galling of the aluminum surface.
We don't use one on out tilton steel flywheels
