Page 2 of 14 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 330
Thread: S50B30US NA rebuild for track car
  1. #26
    NY
    skateboard
    Quote Originally Posted by bluptgm3 View Post
    I would move to a better flowing head pipe - OE OBDII, Jet Hot (if you can find them), Turner Shorties, or eBay-what-ever.
    The raceland reps made great power without cams/intake/540 hfm
    ― George Orwell
  2. #27
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by GG///M3 View Post
    Yeah, those are tits these days, make great power up top with a good tune.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
  3. #28
    NY
    skateboard
    Quote Originally Posted by ScotcH View Post
    Who have you been using for tuning, or are you using none stock ecu?
    ― George Orwell
  4. #29
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    We have Motec and Link ECUs ... so much easier to work with, and no hassles. Our tunes are 2 of the best guys in the business as well, so hard to complain
  5. #30
    NY
    skateboard
    s50 is a nice rod ratio, so if you do keep going, I'd bore it out to 86.5mm, CP/JE 11.5:1 CR pistons, and those s52 cams from GG. Would be a nice reliable pump gas engine. Put some Supertech springs in, and rev to 7600 all day long.
    Great shape
    ― George Orwell
  6. #31
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Talperian is selling a set of Schricks. I paid $750 for mine used. I sold a set for $550 years ago. Last I checked they were about $1150 new. But these are 264/256. For racing you probably want more cam.
  7. #32
    Oct 2007
    Louisville, KY
    1995 M3
    Well, here are the carnage photos as promised. #1 cylinder exhaust side valve head broke off. The retainer and keepers were still holding down the spring with whatever nub of a valve head was left. Not sure if the rod bearing went and contact was made or it was an over rev (not a money shift, but down shifting a bit early). Also looks like the cylinder wall cracked... not sure what happened there. I can feel the crack as well as distortion on the wall... like it had water and froze, but wasn't that.
    Good news!... cams are perfect. I thought that maybe I had done something wrong during assembly but all was good.
    I'll be taking the oil pan off in the next day or so.
    610676E7-69EA-4F64-B756-5782C154D4FE by D S, on Flickr
    833F3442-FB84-4652-A482-118BDD703854 by D S, on Flickr
    5825BDB7-26E9-49FE-B4C3-BE8D17883A1A by D S, on Flickr
    358DFB98-FAF2-4264-BCC1-90B9C725A410 by D S, on Flickr
    8B39AA7A-0CEF-4E95-B8FD-A6EDFD90D288 by D S, on Flickr
    DEF7CAAD-C772-470C-A93F-C0338D331020 by D S, on Flickr
    62775AAA-3734-4BF5-8610-BD851FAAF4F1 by D S, on Flickr
  8. #33
    Aug 2012
    Central, MD
    1995 M3
    Ouch.
  9. #34
    NY
    skateboard
    Wowwww
    ― George Orwell
  10. #35
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    There's your problem! Ya only got 5 complete pistons!
  11. #36
    Feb 2009
    Arizona
    1998 e36
    Quote Originally Posted by bimmerboy318 View Post
    what makes you think it was over-rev?
  12. #37
    Oct 2007
    Louisville, KY
    1995 M3
    Quote Originally Posted by hakentt View Post
    Are you still trolling?
  13. #38
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    That had to be noisy!
    88M3 AW 43k miles Project FS
  14. #39
    Oct 2007
    Louisville, KY
    1995 M3
    Right now this is the plan! I have to keep going!... otherwise, I’ll have nothing to drive for next season.
    Still worried that 11.5:1 CR on the stock cams will need more than 93+ octane. I read that once you go with aftermarket cams, compression actually goes down a bit due to the longer duration of the valves being open.
  15. #40
    NY
    skateboard
    A little off topic, but here is what my s52 made with schrick cams(euro m3 SS exhaust headers/back).
    ― George Orwell
  16. #41
    '97 M3, '95 M3, '93 325i
    Nice. 264/256 I presume?
    Sent from my Pixel 3 using Tapatalk
  17. #42
    They are sold now. Id recommend the OP go with cat cam 275s or schrick 276/270. Or higher, really no reason to shoot for stock power level with a full rebuild.
    I'll have Dyno results on a 11.2:1 S52 with the cat 275s in about a month. Oh and with the s54 itb kit I designed and produced now. Shooting for 300whp, will play with cam timing as well. Starting at 110 for the intake cam lobe center and retarding from there.
    Also running a REAL ATI damper with proper press-fit, mass, and 3 inertia rings. Will spin to 8000rpm and see if we can make power.
    I will then come back to the Dyno again with the stackable shim solid lifter conversion by Perry (someguy2800) to see how power/valve events are affected at higher rpm between hydraulic and solid (valve float).
    Will then come back again with a Turner CSL airbox and see what that does.
    Sorry if derailing your thread a little OP. Please go with some proper camshafts for your build. You won't regret it!
  18. #43
    NY
    skateboard
    Quote Originally Posted by Talperian View Post
    Yep with proper exhaust mods, and the best tuner
    ― George Orwell
  19. #44
    Well done, I've seen these results before that cam.
  20. #45
    NY
    skateboard
    Hi . I’ll most likely be moving onto something else. I get bored quick
    ― George Orwell
  21. #46
    Hi . I’ll most love moving onto something else. I get bored quick
    Sorry, meant to say "...before with that cam".
  22. #47
    Oct 2007
    Louisville, KY
    1995 M3
    Thanks for all the input guys. I just want a 110% reliable HPDE car that I don't have to "worry" about. If I can get that kind of power on the mild Schrick's, not sure if I want anymore.
  23. #48
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Nice looking mods and fun project! As a comparison and some data, our build we made 307/249 rear wheel (hub dyno) with the following mods:
    s52 12.5:1 CR
    cat cams 290 12.5mm lift
    hydraulic m50NV lifters
    modified Schrick intake (bigger plenum)
    80mm TB
    98 octane Sunoco
    And on the same dyno, 329/271 rw on with s54 with the 304 schricks and pump gas.
  24. #49
    s52 12.5:1 CR
    80mm TB
    98 octane Sunoco
    Thank you!
    Impressive with the s52, hopefully I get close! Do you have a dyno graph? I'd love to see at what rpms you were making power, etc...
    I don't know much about hub dynos, but the s54 dyno numbers look low for that camshaft with I'm assuming supporting typical modifications?
  25. #50
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Here is the dyno graph. Forgot to mention, also have an ATI damper ... we run the engine to 7800 on track.
    The s54 is build for enduro (6+ hrs), so we kept it safe. Has the typical mods, SLC coated stuff, and is cable drive, Alpha tune (link ECU). Here is the s54 graph
  1. Let's talk cylinder head rebuild options for track cars
    By TXBDan in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-05-2016, 11:17 PM
  2. NA: E36 M3 Dakar Yellow track-car-worth
    By BeLiQ in forum Texas
    Last Post: 09-24-2012, 02:46 PM
  3. S50B32 weight vs. S50B30US for track car
    By avusm3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-04-2008, 10:32 PM
  4. E31 400HP NA Track Car - motorswap
    By daedal in forum 8 Series (E31)
    Last Post: 01-01-2006, 01:22 AM
  5. Water/Alcohol Injection on an NA Track car???
    By Spencer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-14-2003, 08:11 PM
