Results 1 to 20 of 20
Thread: Soft Top replacement best source?
    Jun 2016
    Somewhere, USA
    2001 BMW Z3
    Hi.
    I purchased my Z3 with a vandalized roof (sliced up top). It's not a huge deal for me, because it'll be down most the time. But thinking about replacing it, any recommendations for a retailer?
    This place looks pretty cool?
    https://www.convertibletopguys.com/category/view/223
    Thanks!
    Jan 2016
    Ca
    2001 525it
    I would call a upholstery shop and see what brands they recommend
    Jun 2016
    Somewhere, USA
    2001 BMW Z3
    Quote Originally Posted by jclausen View Post
    Totally didn't think of that. Thanks!
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    Save your sealing frame. They are currently unavailable. I bought a GAHH Sonnendeck top and was very satisfied.
    Kelvin
    Jun 2016
    Somewhere, USA
    2001 BMW Z3
    Quote Originally Posted by KBH22102 View Post
    I'm looking at the "GAHH" site now, price is reasonable. I suppose it's an art to properly install? Meaning, I shouldn't take on the task myself?
    Thanks!
    McLean, VA
    A forum member has posted a step by step guide. If you think this is beyond you, then find an auto upholstery shop to do the work.
    https://webspace.ringling.edu/~dplassma/str/str.html
    Kelvin
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    I would do that, because they may have a relationship and experience with one supplier, and also because they may not want to install or stand behind any top that an owner brings them.
    I had a local shop install my top, and they had a catalog and buying relationship with GAHH. So I chose a GAHH Twillfast top, they called me when it came, I dropped off the car and picked it up in 8 hours.
    BMW MOA 696, BMW CCA 1405
    Jan 2018
    Mojave Desert, California
    '01 Z3 3.0i, '01 X5 3.0i
    I got a Robbins top. I had to warranty it because the plastic tabs at the front cracked, so I got a free replacement with fabric tabs after sending them photos. Great quality, perfect fit, and it’s been great for over 2 years now. Only difference between it and the stocker is the stitched in window.
    I self-installed partly because there are no reputable upholstery shops in my area.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by nahvkolaj View Post
    I got a Robbins top... I self-installed partly because there are no reputable upholstery shops in my area.
    Robbins, GAHH, German Auto Tops, Auto Tops Direct and Tops Online appear to be of equal good quality. After I viewed the classic DIY at https://webspace.ringling.edu/~dplassma/str/str.html, I thought few owners would be able to do it themselves. Of particular concern would be the plastic sealing ring which apparently can break in removal, is not likely to seal if replaced in pieces, and a new sealing ring is very expensive with a long order time.
    Feb 2019
    PA
    2001 BMW Z3
    Yes the sealing frame is key....A lot of vendors have it on backorder.
    Jun 2016
    Somewhere, USA
    2001 BMW Z3
    I'd rather do it myself (if possible), I'm not mechanically challenged. I'll take a look.
    Thank you
    Have a feeling, I'm going to try myself.
    May I ask how long it took?
    Quote Originally Posted by Vintage42 View Post
    Sounds like "Robbins" is the way to go? I should stay away from the $300 ones on eBay or Amazon?
    Sep 2003
    kansas city
    98 Z3, 01 330i, 07 328iT
    There are basically three options for good quality, non-oem tops. Robbins, Gahh, and Sierra auto tops. Most of the unbranded ones on eBay are from Sierra. If you get the twillfast, you will get a good top. I installed a Sierra in mine last year and I’m pleased with it.
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    Easier said than done, mine fell apart in my hands upon removal. I was lucky to find one on eBay from some Eastern European company.
    Jan 2012
    Golden, CO
    1996 Z3
    I did the Sierra Tops with my son about a year ago and am very pleased with the quality.
    It took about 6 or 7 hours, only because we took our time and had several write ups including the instructions sent with the top and followed the steps closely. If we did it again we could probably do it in 3-4 hours
    You do not need to take the plastic sealing frame out of the car, there is a metal frame the top is stapled to that is what you need to remove. If you remove it carefully your plastic sealing frame will stay bolted and intact to the body of the car without damage. From the inside of the car you have the metal frame, the actual top, the plastic sealing frame and then the body of the car. Do not remove all of the bolts holding the top in, there are about 6 of the bolts that hold in the plastic sealing frame separately and if you leave them you will not damage it.
    Jan 2018
    I did the top replacement in two days. One day to uninstall and clean up old butyl sealant, the next day to do the install.
    I also did not remove the plastic sealing frame. Mine was cracked right in the middle. I repaired it with epoxy and used some extra butyl there. No leakage problems for two years now, verified when I had the rear cabin carpet out for shock mount replacement. My Z3 is my daily driver and I drive it in the rain.
    I would recommend ordering from a reputable convertible top website. I ordered my Robbins through Topsonline. When The first top I ordered was faulty, I just sent some pics of the fault and I got a new top back at no extra cost to me.
    Jun 2016
    Somewhere, USA
    2001 BMW Z3
    The install instructions are somewhat intimidating! I'm sure it's all about pacing yourself.
    Jan 2012
    Golden, CO
    1996 Z3
    If you PM me your email I can send you the instructions from Sierra Tops, it along with Vinci’s instructions is what I used.
    Mar 2021
    Vienna VA
    1998 M Roadster
    Can anybody find a new Sealing Frame out there? I can't find one anywhere.. I assume they are all the same but I have a 1998 Z3 M
    Feb 2019
    PA
    2001 BMW Z3
    I have not seen it available in the last year or so...I hope they have not stopped production of them.
    Sep 2003
    kansas city
    Someone should make a metal reproduction of the sealing frame. That OE plastic just gets too brittle over time.
  1. Recommended Soft Top Replacement Source
    By Submariner2009 in forum 1983 - 1991 (E30)
    Last Post: 07-15-2017, 02:49 PM
  2. Soft Top Replacement
    By Solokron in forum Convertible Questions
    Last Post: 10-22-2008, 02:12 AM
  3. Soft Top Replacement
    By Solokron in forum 1991 - 1999 (E36)
    Last Post: 09-17-2008, 10:29 PM
  4. Recommended soft top replacement?
    By 98point6ny in forum Convertible Questions
    Last Post: 03-19-2008, 07:50 PM
  5. Soft top replacement
    By JohnC8551 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-06-2007, 01:36 PM
