Results 1 to 7 of 7
Thread: Swapping driver seat from 2014 BMW F10 to 320i
    Sep 2020
    Marlborough ma
    2014 BMW 320i
    I tried swapping the driver seat from an 2014 F10 to a 320I and when I connected it there was no power. Can anyone please advise me what to do?
    You're putting a seat from a 5 into a 3. They are completely different. I hope you have a full wiring schematic and a degree in automotive engineering. What made you think that would be a straight swap?
    Sep 2020
    Marlborough ma
    2014 BMW 320i
    I misspoke. I swapped a 320i seat with an F30 seat. Shouldn’t it fit
    Physically it will fit, as the body is the same, so mounting holes and all that will line up. However, depending on how the cars we’re equipped from the factory, the wire harnesses may be totally different. There might be modules that one has and the other doesn’t. There could be fuses, or relays for one car that aren’t in place in the other.
    I think you may have mistakenly taken on a bigger project than you thought. What exactly were you trying to accomplish? Adding heated seats or power seats? Swapping from non-sport to sport seats?
    Sep 2020
    Marlborough ma
    2014 BMW 320i
    My intent was to upgrade the seat and to add lumbar support
    I already had power seats. I wanted added comfort and lumbar support
    The only way I would know of is to get wiring diagrams of both and start comparing. Do they have the same modules, connectors, etc?
    Sep 2020
    Marlborough ma
    2014 BMW 320i
    We ended up swapping out the control modules and it worked! The only thing that we weren’t able to do is to connect the lumbar support because the old module didn’t have the connection. Do you know if there is a way to chronic lumbar support?
  1. Seat Part Swap: Sport Seat Pass into Drivers Side
    By fun2drive in forum Convertible Questions
    Last Post: 12-19-2008, 04:40 PM
  2. 1996 328is passenger-driver seat cushion swap
    By berkeleyEE in forum 1991 - 1999 (E36)
    Last Post: 07-16-2008, 07:50 PM
  3. Pass / Driver Seat Swap Possible?
    By Hess in forum 1991 - 1999 (E36)
    Last Post: 12-01-2007, 12:57 PM
  4. Swap driver & pass. seats?
    By tatahey44 in forum 1995 - 2001 (E38)
    Last Post: 11-27-2007, 02:57 PM
  5. Swap driver and passenger seats?
    By bitchincamaro in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2006, 03:52 PM
