Results 1 to 6 of 6
Thread: Starter Replacement BMW Z4 2003 3.0 Roadster Manual Transmission
    Sep 2020
    Newburgh, IN, USA
    2003 BMW Z4 3.0 Roadster
    I was having some sluggish starts on my BMW and now it does not start. After checks to batter and alternator determined this to be a starter issue. I was able to start the car by tapping with a wooden stick on the bell housing near the starter several time which turning the ignition. I am now trying to remove the starter on my Z4. Can this be accomplished without removing the air intake manifold? Some seem to have done this without on some models. Any advice would be helpful. Thank you.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    While replacing a starter motor is a good excuses to take the inlet manifold off and do all the preventive maintenance that the removal allows for, you can remove the starter by going in from the bottom. This is difficult and requires you to reach in and do things in the blind.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    How many miles on the Z? The consensus here and on other bimmer forums is that the cooling system needs to be overhauled at 100k miles. If the car he as more than 150k miles on the clock it’s a really good idea to replace the plastic cooling system pipes under the intake manifold.
    Mar 2019
    ATLANTA GA
    456 X3s
    Of course its your choosing, many will point to removing the starter from the bottomas best. My preference is from the top. This gives me a better understanding of the process and an opportunity to inspect other vital pipes hoses and sensors. But some like working in the blind with extensions...I may try it one day when I have time to compare methods.
    Cheers!
    Sent from my SM-J727T using Tapatalk
    Jan 2016
    Ca
    2001 525it
    I would remove the intake manifold and replace the plastic coolant pipes while doing the starter
    Jun 2012
    New Mexico
    2003 328i
    You can remove the intake duct and throttle body to access it from the top. No need to pull the manifold. No matter which way you go, the job sucks.
  1. FS: 2003 BMW Z4, 2.5l , 74k miles, Manual transmission
    By joluga123 in forum 3 series & Z Series
    Last Post: 12-02-2018, 07:59 PM
  2. BMW Z4 2003 E85 3.0i - cannot identify replacement part from diagrams?
    By GreenieP in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-06-2017, 09:46 AM
  3. Z4 E85,E86 2003 BMW Z4 2.5i - Black/Black - Manual - 44,000 Miles
    By Global Autosports in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-15-2012, 12:58 AM
  4. BMW Z4 - 2003 - Airbag light
    By shayan in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 10-17-2008, 12:11 PM
  5. 2005 (05) BMW Z4 SE 2.0i ROADSTER TITANIUM SILVER - FOR SALE
    By Scotte in forum BMW Cars For Sale / Wanted
    Last Post: 08-23-2006, 07:57 AM
