Had to pull a wheel off a 530i to get a caliper. Of course the lug bolts were tight as hell.
My Porter Cable impact didn't do it and of course my breaker bar was in my car. Had to use the Armstrong method and a ratchet to get 4 of the 5 loose, for the 5th I had to borrow a breaker bar from a guy that asked to borrow a phillips from me. That little extra bit of leverage was what I needed to get the bolt loose.
The moral of the story is get a second, long, 1/2" drive breaker bar and keep it in my go bag. Or buy a Impact with more "round spherical objects" . Mine is rated at 330 ft/lbs but it does not like BMW lug bolts.
Harbor freight earthquake impact gun man, cheap and angry just like me.
Sent from my SM-G973U using Tapatalk
Spray WD-40 or PBblaster on the bolt...
M18 Milwaukee impact gun, damn things got big balls, over 1200 ft lbs of reverse torque. Damn thing is awesome.
You couldn’t find a lug wrench in any of the cars at the yard??
Hope you saw my edit to your 1st post above.
Yes, seriously. Us Mods don't make the rules, however we are tasked to make sure everyone follows them.
Vendors pay to keep this forum running, if it becomes vulgar they leave. No paid advertising = no forum.
KEEP YOUR POSTS, AVATARS, AND SIGNATURES TASTEFUL
The Main Forums of Bimmerforums.com are a place for PG material only where explicit, obscene or vulgar gestures, language, GIFs, JPEGs or other graphic files are NOT appropriate. Message board titles, posts, avatars, and signatures in all forums that contain anything that is not considered PG material will not be tolerated and will be moved or deleted without notice! The enforcement and definition of PG is solely the responsibility of the Administrators and Moderators. (see the “Off-Topic” forum section below for exceptions).
Funny that you should mention this. I'm assuming you have the "fuel" version which I think is brushless.
Being the fool I sometimes am I neglected to undo the crank bolt on an M50 before pulling it and removing the head. My brush motor M18 rattled away until the battery died. A friends 20v IR rattled away long enough to heat the socket. Another friend's M18 ("fuel") brushless with 9a battery shook it few times then zipped it right off.
When I bought my brushed M18 I scoffed at the "fuel" version. Lesson learned.
Hell yeah. Shoot, I’ve even tried it on lug nuts of an 18 wheeler, it just laughs at it and says “ Is that all?”.
